TRD Lowering Springs Camber.
About a week ago I installed the TRD lowering springs on my 2013 FR-S. When I went in to get an alignment done today the left rear camber was at -1.5 degrees and the right rear was at -2.6 degrees. I understand that dropping the car an inch will add negative camber but it seems odd that the right is 1.1 degrees off from the left. anyone have an idea as to why this would happen? for what its worth the front left is -.1 and the front right is -.4
#2 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
I'm sure others will chime in, but I believe this is just a matter of how the springs settled and how they were installed. This is why you're supposed to get an alignment as you have done after swapping out suspension components.
#3 | |
Drives: Harrop TVS86 STi BRZ tS
Was the alignment guy able to correct the camber at all? When I went in they told me that it was not possible.
#4 |
2.6 something may be wonky, worth checking the install. Highest I've heard of is 2.1 or so.
| The Following User Says Thank You to vroom4 For This Useful Post: | strat61caster (10-23-2015) |
#5 |
Drives: frs
Mine ended up similar, 1.7 lr and 2.5 rr
#6 |
do you know what your stock alignment was? it might have been off from the factory. my stock camber was pretty even at -1.3 both sides in the rear. I don't know how you would find that much of a difference by just swapping out springs, unless you didn't seat them correctly on the perch
#7 | |
#8 |
Drives: 2014 BRZ - 2004 GLI
Mine was dead on -2 on both sides.
#9 |
Could curbing the rear wheel throw the alignment/camber off? When I bought the car the right wheel was scratched and the tire had a chunk taken out. No damage to internals just looked like somone rubbed a curb pretty good.
#10 |
I don't think the wheel itself would cause a camber issue, but maybe the previous owner bent something in the suspension when he/she curbed the wheel. Worth looking into...
-Seth |
| The Following User Says Thank You to vividracing For This Useful Post: | wparsons (10-26-2015) |
#11 |
| Thinking about lowering and camber adjustment, recommended shops in PDX? | Llilith | Northwest | 4 | 09-08-2015 11:36 AM |
| What is needed for a proper alignment after lowering 1in? LCA's, Camber bolts? | CallmeDave | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 05-17-2015 09:26 PM |
| Lowering - best way to adjust camber? | _frs | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 08-28-2014 04:35 PM |
| Rear camber after lowering | mike_ekim1024 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 06-09-2013 04:01 AM |
