Old 10-09-2015, 08:51 AM   #1
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
Question clicking on take off
this isn't even a hard take off. even slight acceleration from a stop and I get this clicking sound from what sounds like the rear left wheel area. is this normal or anything to worry about? I have never touched the suspension of the car. I've put on new wheels and that's about it.
Old 10-09-2015, 09:50 AM   #2
TEWwild
TEWwild's Avatar
Drives: 2015 Ultramarine FR-S MT
Check the axle nut, I had the same issue and the axle nut had backed off about half a turn. It should be crimped into the slot on the axle.
Dealership retorqued and crimped, no charge...
TEWwild is offline   Reply With Quote
Old 10-09-2015, 11:42 AM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Axle nut loose, or axle going bad.
Old 10-09-2015, 06:58 PM   #4
echo419
echo419's Avatar
Thanks. I'll check that out
Old 10-09-2015, 10:05 PM   #5
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
If re-torquing the existing axle nut doesn't work, i'd replace the nut and re-torque. I had the exact same problem on both rear axles, the nuts fixed it
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 10-09-2015, 10:23 PM   #6
Rookie84
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
I had the same issue albeit on a different car. G35s were notorious for this and there was a TSB on it as well. The problem - axle nuts or axles themselves like everyone else had mentioned.
Rookie84 is offline   Reply With Quote
Old 10-12-2015, 01:19 PM   #7
dvasqu01
dvasqu01's Avatar
Drives: Scion FRS Whiteout
I've actually have the same issue but it's in the front and it happens when I stop at times
I'll give you the rice noodle😘
dvasqu01 is offline   Reply With Quote
Old 10-12-2015, 01:50 PM   #8
echo419
echo419's Avatar
it was a loose lug. all is well.
Old 10-16-2015, 05:37 PM   #9
Pat
Pat's Avatar
Drives: 2023 BRZ
I think I have the same issue. Do you guys remember the nut size and torque spec?
TIA
Pat is online now   Reply With Quote
Old 10-24-2015, 05:43 PM   #10
echo419
echo419's Avatar
Torque is 90 or 95 iirc. But I'm not sure.
Found the problem. Something broken in the e-brake. It was loose and causing the click. Under warranty so I don't care.
Old 11-01-2015, 02:50 PM   #11
Pat
Pat's Avatar
Drives: 2023 BRZ
According to this link, the axle nut is 32mm and torque spec is 140 ft-lbs.
Old 11-01-2015, 06:01 PM   #12
echo419
echo419's Avatar
Oh, thought he was referring to the lugs
Old 11-08-2015, 11:26 PM   #13
Pat
Pat's Avatar
Drives: 2023 BRZ
Should I get a new nut or can I just retorque the one I have? I'm a little worried about the crimping of said nut, as it looks like there my be a special tool necessary to do this job. Thoughts?
Old 11-09-2015, 12:58 AM   #14
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Yes, its best to replace the nut (got mine for $7). No special tools needed, just a good flat head screw driver an a hammer. To remove, stick the screw driver at the key/cut-out on the axle to bend back the crimp. When you're done torquing down, use screw driver tip to tap down the crimp.
FRS Clicking/Tapping sound DCStorm Issues | Warranty | Recalls / TSB 30 12-29-2017 09:59 AM
Clicking noise from exhaust? azynneo Issues | Warranty | Recalls / TSB 6 06-16-2015 02:05 PM
Clicking sound when shifting into 4th? Marcbrz86 BRZ First-Gen (2012+) — General Topics 4 05-19-2015 08:52 PM
Clicking with Sharp Turns carma143 BRZ First-Gen (2012+) — General Topics 7 12-09-2014 12:43 AM
Clicking From Wheel Area martinEZ Issues | Warranty | Recalls / TSB 9 06-03-2014 10:17 AM
