Old 05-18-2015, 02:24 PM   #1
Marcbrz86
Drives: 2015 Subaru BRZ Series Blue
Clicking sound when shifting into 4th?
I was at a stop light and the roads were empty so I decided to wring the car out, and when shifting into 4th at around 5500-7000 rpms I hear a loud clicking like plastic snapping into place, I don't think it's grinding because there's no extra resistance just a loud clicking/snapping sound and it only happens in 4th at those rpms anyone else notice this?
If this has been mentioned before please link the thread.
Marcbrz86 is offline   Reply With Quote
Old 05-18-2015, 08:08 PM   #2
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
That clicking sound is coming from the plastic piece that you normally lift up in order to shift into reverse.
krayzie is offline   Reply With Quote
Old 05-19-2015, 08:36 PM   #3
Marcbrz86
Thanks
Old 05-19-2015, 08:45 PM   #4
chas3wba0
chas3wba0's Avatar
Drives: Yes
I always thought it was the synchros clicking into place. It became more muted after I switched to Motul 300 tranny fluid, and also isn't as apparent when I take a little more time with the 3rd-4th throw.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 05-19-2015, 08:52 PM   #5
krayzie
Drive From Home
krayzie's Avatar
Nah the synchros would be like a metallic sound.
The reverse gear lifter (I don't even know what's the correct name for it) is held down by a spring loaded cable, but it hops a tiny bit if you shift into a gear that has a little resistance, so it makes a stupid pop noise.
This became noticeable to me after installing the STI short shifter, and when shifting at high rpm range which would obviously require a little more force compare to low rpm shifting.
FRS Clicking/Tapping sound DCStorm Issues | Warranty | Recalls / TSB 30 12-29-2017 09:59 AM
Clicking behind dash when shifting out of park? brsaresmgs Issues | Warranty | Recalls / TSB 3 02-11-2015 08:41 PM
Clicking noise when shifting from Park to Reverse -AT 01s0uljah Engine, Exhaust, Transmission 1 10-30-2014 06:39 PM
clicking/tapping noise when shifting semi hard Skurge Issues | Warranty | Recalls / TSB 3 09-20-2013 04:37 PM
Clicking shifting 2nd gear and R radroach Issues | Warranty | Recalls / TSB 0 03-16-2013 11:36 AM
