Old 06-01-2014, 02:04 PM   #1
martinEZ
martinEZ's Avatar
Clicking From Wheel Area
So today was a normal Sunday. On my way to church as I arrived in the empty parking lot, I did a quick slide which is nothing different from what I do any other day (see empty lot, make car slide, repeat). Only this time, about an hour or so after, when I got back in and started driving I noticed the clicking/popping.
My observations are as follows:
The clicking occurs at the same rate the wheels are rotating. When I speed up it speeds up and vice versa. Regardless of speed, even slow creeps, it pops.
Also I have assured myself it is coming from outside the vehicle, using my patent pending echolocation test. This test consists of driving in an open area and listening and then driving next to fences and listening to the change in sound level. I doubt science supports me, but I hear it clear as day near the fences and not so much I'm open space.
I did a visual inspection and found nothing. I am fairly confident it is coming from the rear wheel area or somewhere in between.
I'd rather not take it in to the dealership but if I can't figure it out then I'll have to.
The only thing in the wheel area that is aftermarket is RallyArmor Mudflaps and plastidip.
Any help is beneficial.
Last edited by martinEZ; 06-03-2014 at 09:19 AM. Reason: Further observations must be noted
martinEZ is offline   Reply With Quote
Old 06-01-2014, 02:20 PM   #2
sirsol66
Drives: 2013 FRS- Hot Lava
Most likely axles. Jack up the car and spin the wheel, see if it's the front or rear to isolate if it's axles.
sirsol66 is offline   Reply With Quote
Old 06-01-2014, 03:20 PM   #3
jeffsquared
Drives: 2013 FR-S 10 Series #1186
This happens to me when rocks get stuck in my tire tread. Happens in my mazda too.
sent via mobile.
jeffsquared is offline   Reply With Quote
Old 06-01-2014, 03:42 PM   #4
Muskokan
Drives: white Sport-tech
Did you try kicking it?
Muskokan is offline   Reply With Quote
Old 06-02-2014, 12:28 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
What brake pads do you have?
-alex
Old 06-02-2014, 03:08 PM   #6
andrew20195
Drives: 2013 Subaru BRZ
My best guesses based on your description would be
1. Rocks (or a nail/screw/bolt) stuck in the tire tread, with or without a puncture.
2. Loose lug nuts. Probably not likely unless your wheels were recently removed, though higher power cars have been known to stretch and loosen lugs due to power/wheelspin
3. Axles wearing out. More likely if you're lowered, but you didn't mention anything about that.
andrew20195 is offline   Reply With Quote
Old 06-02-2014, 05:43 PM   #7
Pat.Thornton
Pat.Thornton's Avatar
Drives: 2014' 86
This happened to me on the stock tires... I found out after a few days that it was just a small stone stuck in the tread. Hope this helps
Pat.Thornton is offline   Reply With Quote
The Following User Says Thank You to Pat.Thornton For This Useful Post:
FRSBRZGT86FAN (06-17-2014)
Old 06-02-2014, 05:45 PM   #8
G.I.Choe
Drives: 2013 Scion FRS Argento
Had this issue on mine. Took it to the dealer, turned out to be undertorqued axle nuts. They tightened everything up to spec, issue's gone.
G.I.Choe is offline   Reply With Quote
Old 06-03-2014, 08:19 AM   #9
martinEZ
martinEZ's Avatar
Dealer saw it and said it was an exhaust leak, but my guy is gonna take it overnight a week or so from now to check if the leak is more prevalent in the morning on a cold start, as he's not entirely ruling out the axle because I brought it to him yesterday and he couldn't find where the leak is coming from due to the hot piping possibly expanding to cover it after the car is warmed up.
Run-on sentence FTW
Old 06-03-2014, 10:17 AM   #10
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
Anyone know the torq spec for the axle nuts?
marcoaferrer is offline   Reply With Quote
FRS Clicking/Tapping sound DCStorm Issues | Warranty | Recalls / TSB 30 12-29-2017 09:59 AM
Clicking noise in engine bay teddydoggy Issues | Warranty | Recalls / TSB 4 08-12-2013 04:15 AM
Clicking coming from rear.. HillCountryGuru Issues | Warranty | Recalls / TSB 3 03-22-2013 12:05 AM
Clicking shifting 2nd gear and R radroach Issues | Warranty | Recalls / TSB 0 03-16-2013 11:36 AM
Clicking noise? Not crickets... Laika Issues | Warranty | Recalls / TSB 4 10-18-2012 06:39 PM
