Old 09-27-2015, 01:59 AM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Brake Pads + Rotor
Hey guys, its almost time to change the rotors and brake pads. The rotors are still good, although... I want to change it lol.
I did search and read few, but most of you track the car. I don't track the car. I daily drive the car, I have a winter in which I use the car
I am looking for good brake pads and rotor kits. I looked at the hawks but I am open for more ideas.
Budget: 900$ for front and wheel
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 09-27-2015, 03:01 AM   #2
swarb
What did you like/dislike about the oem?
Why replace rotors that are good?
I would say get a used set of oem rotors and pads.
Or centric rotors and some low end performance pads like stop tech.
Old 09-27-2015, 11:06 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Go with OEM brake pads. Rotors, eh anything will do. If your rotors are not worn down there is no need to replace them.
If your not going to track, there is zero reason you need better pads. Unless you want break squeaks every time you use your brakes. Cause that's what performance brake pads do.
Old 09-27-2015, 11:21 AM   #4
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
If you want to hard park, I suggest Brembos and drilled, slotted rotors. Or just paint the stock rotors red.
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
drewbot (09-27-2015), wparsons (09-28-2015)
Old 09-27-2015, 11:46 AM   #5
OkieSnuffBox
Drives: '23 BRZ Limited
Buy stock.
Why is this even a question?
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post:
Sleepless (09-28-2015), wparsons (09-28-2015)
Old 09-27-2015, 03:11 PM   #6
Mikeez
Engineering Student
They have some sign of wear, and I was thinking slotted/driller rotor. However, for the brake pads they are almost done. StopTech is a low end performance good for street use? Which one from their models should I get?
Should I just get OEM everything?
I understand your logic, you are right. Is there something better than OEM however doesn't squeak?
That's like 6k.
Old 09-27-2015, 03:44 PM   #7
EAGLE5
Dismember
EAGLE5's Avatar
6k for a new purpose built set. much cheaper to take off and mod from another car. i think the 300zx brembos fit, or something.
Old 09-28-2015, 12:13 AM   #8
Just get more OEM pads. They work great, and are perfect for what you use the car for. Re-use your rear rotors.
You budgeted $900, this is gonna cost you less than $100. Put the other $800 in your portfolio/savings account and we'll call it even.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Dave-ROR (09-28-2015), Sleepless (09-28-2015), wparsons (09-28-2015)
Old 09-28-2015, 01:47 AM   #9
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
You can go all OEM if you want to.
Nope. Performance brakes don't work that way. The better the pad the more noise.
Old 09-28-2015, 04:01 AM   #10
strat61caster
strat61caster's Avatar
TRD Pads would run you about $130-$150, supposedly a small upgrade from stock.
ineedyourdiddly
Old 09-28-2015, 10:50 AM   #11
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Will they squeak a little? Sure. But properly bedded pads shouldn't squeak all of the time.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
Old 09-28-2015, 11:03 AM   #12
jvincent
jvincent's Avatar
I'm curious how you managed to kill the stock brake pads that quickly without taking your car to the track.
Old 09-28-2015, 11:05 AM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Especially in the back... I never wore out track pads on the back and they were on the car for over 30k miles and a number of track days.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Old 09-28-2015, 11:08 AM   #14
jvincent
jvincent's Avatar
Yeah, I just changed my front track pads out because they were about 15-20% left (better safe than sorry) and the backs are maybe 25% used.
I fried my OEM pads last year at the track (that's what I get for being lazy and not changing them) but up to that point they were barely worn.
The Following User Says Thank You to jvincent For This Useful Post:
DIY: Front Brake Pad and Brake Rotor Replacement F1point4 DIY (Do-It-Yourself) Guides 28 03-21-2021 09:22 PM
Brake Rotor Runout gdrider77 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-20-2015 12:43 PM
Seized brake rotor removal tool fstlane DIY (Do-It-Yourself) Guides 15 09-06-2015 12:38 AM
R1 Concepts rotor, and brake pads ExtremeAutowerks Brakes, Suspension, Chassis 37 12-23-2013 02:39 PM
