Old 09-20-2015, 12:43 PM   #1
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Brake Rotor Runout
So im troubleshooting a few things, Got a question around this. usually many manufacturers provide a max runout .005 for example.
Im running willwood and they list allowable runout as .005 - .008.
So does that mean that up to .008 is max allowable? Just seems like a weird way to list it. Is .005 the minimum, so then im out of spec?
The way i read this is that i can go from .000 - .008 Isnt 0 always best possible?
Im currently at
Pass.005, Drivers.004
So i think im good, but if i need .005 to be minimum then my drivers at .004 is out of spec.
Any help.
Thanks all!
gdrider77 is offline   Reply With Quote
DIY: Front Brake Pad and Brake Rotor Replacement F1point4 DIY (Do-It-Yourself) Guides 28 03-21-2021 09:22 PM
Seized brake rotor removal tool fstlane DIY (Do-It-Yourself) Guides 15 09-06-2015 12:38 AM
R1 Concepts rotor, and brake pads ExtremeAutowerks Brakes, Suspension, Chassis 37 12-23-2013 02:39 PM
Has anyone cracked the OEM rotor yet? ayau Tracking / Autocross / HPDE / Drifting 10 04-22-2013 04:41 PM
Brake rotor differences between base and Sport-tech BRZ Sport-Tech CANADA 10 04-12-2013 07:15 AM
