Old 08-11-2015, 02:13 AM   #1
failingpig
Drives: 2011 camaro
Boost questions.
So I'm looking into acquiring a 2014 FRS but I have some questions. I would want to boost it but I don't know what the engine is good for power numbers. I'm wanting to try and get power numbers around 400whp. What would I have to do to the engine to make it hold the power. Thanks for any help!
failingpig is offline   Reply With Quote
Old 08-11-2015, 02:14 AM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
400 whp on what type of fuel?
Freeman is offline   Reply With Quote
Old 08-11-2015, 02:16 AM   #3
failingpig
Drives: 2011 camaro
It would have to be 93. No where conveniently around me has anything else.
Old 08-11-2015, 02:21 AM   #4
Freeman
Freeman's Avatar
Lower compression Pistons, forged rods, turbo.
That's not counting the oil cooler, and trans upgrades to handle the power. Perhaps even axels if you like to launch it. Brakes and tires to keep you from crashing and driving up the insurance rates.
Old 08-11-2015, 03:17 AM   #5
failingpig
Drives: 2011 camaro
Do we have any idea what kind of power numbers the transmission is capable of before grenading?
I can't find anything. It's all from 2012 when the car first came out and no one knows.
Old 08-11-2015, 03:33 AM   #6
You're gonna need to build your engine.
Old 08-11-2015, 03:34 AM   #7
Typically anything over 285wtq is a ticking time bomb.
Old 08-11-2015, 08:30 AM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
My advice is stick to the Camaro if you want 400 whp on 93 octane.
The Following 5 Users Say Thank You to King Tut For This Useful Post:
ATL BRZ (08-11-2015), Freeman (08-11-2015), glamcem (08-11-2015), Premium 615 (08-12-2015), raven1231 (08-11-2015)
Old 08-11-2015, 11:18 AM   #9
wootwoot
Drives: FRS
Depends on how long you want to make 400hp.....
How did you decide you needed 400hp anyway? Why not 350? Or 450?
wootwoot is offline   Reply With Quote
The Following 2 Users Say Thank You to wootwoot For This Useful Post:
kch (08-11-2015), strat61caster (08-11-2015)
Old 08-11-2015, 02:47 PM   #10
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
let me think, you want to make 400whp on a car that is originally designed to make only 165-170whp ..that's nearly 2.5 times of the current output.. unless you have deep pockets and time, it sounds like a very bad idea
glamcem is offline   Reply With Quote
Old 08-11-2015, 03:11 PM   #11
STV3
Señor Member
STV3's Avatar
If you are talking about turbocharging the car before you even purchased one, then this is not the car for you. Buy something else that already comes with more power and save yourself the headache.
STV3 is offline   Reply With Quote
The Following 3 Users Say Thank You to STV3 For This Useful Post:
kch (08-11-2015), raven1231 (08-11-2015), strat61caster (08-11-2015)
Old 08-11-2015, 03:49 PM   #12
raven1231
This couldn't be more true. If you need more power before even driving the car then you should just cross it off your list.
Old 08-11-2015, 03:54 PM   #13
glamcem
glamcem's Avatar
but why? I knew that I was going to order some sort of FI solution before even purchased my car simply because FA20 engine sucks big time in stock form when it comes to throttle response and the torque dip, it's also extremely underpowered the only real solution to overcome that is to get some sort of FI.. the problem here is the power goals IMO, 400whp is just too much and will definitely cause a lot of headaches down the road
Old 08-11-2015, 04:10 PM   #14
STV3
Señor Member
STV3's Avatar
And I'm sure that you didn't make threads like this either
http://www.ft86club.com/forums/showthread.php?t=61484
http://www.ft86club.com/forums/showthread.php?t=58948
http://www.ft86club.com/forums/showthread.php?t=58492
The Following User Says Thank You to STV3 For This Useful Post:
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
BRZedit and boost. (also wondering BRZedit vs ECUtek with boost) NickFRS Software Tuning 43 03-10-2014 04:10 AM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Boost and mixture gauge questions mike the snake Forced Induction 9 07-29-2013 07:55 PM
