Drives: Firestorm 2013 FR-S
any real fix for non-linear throttle?
My apologies in advance for not searching for this topic, but I couldn't find anything after searching using a dozen different word combinations.
This car has the typical "Japanese" throttle response, where you get a lot of response with the first bit of pedal motion and the gain beyond that point is much less. I tried the "disconnect battery, reconnect, then depress pedal 15 times" (or whatever it was) but it made no discernable difference. Does the car really "learn" your driving style or is that BS?
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
Drives: 86
Most tuning solutions let you alter the throttle mapping to your liking.
Drives: Toyota 86 GTS
AT or MT?
AT. But when in Sport or Manual mode the torque convertor is locked up, so it is difficult to feed in a little throttle without the car without jerking
Yes, the AT map is non linear compared to MT. The only choice you have is a tuning platform. The good news is you can just copy the MT map directly over. No actual tuning required.
#6 | |
Can you recommend which would be the easiest / least expensive platform? I have to admit my ignorance-- is this something I can do myself? Thank you, Jim
Openflash tablet. See software sub forum.
Drives: 2013 ultramarine Scion FR-S
OFT would be easiest.
Tactrix would be least expensive. |
| Part throttle faster than full throttle | brn12345 | Engine, Exhaust, Transmission | 38 | 10-21-2021 12:20 PM |
| Linear (No progressive) springs | Mikepage | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 34 | 08-23-2014 05:23 PM |
| AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? | tracerit | Engine, Exhaust, Transmission | 11 | 02-15-2014 12:44 PM |
| 5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 08-06-2012 07:44 PM |
