Old 02-08-2013, 01:17 PM   #1
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Linear (No progressive) springs
Hi,
I want to know which aftermarket springs are not progressive.
Some info about this subject : @Koji_Online
linear spring simply gives you a more direct feeling
http://www.ft86club.com/forums/showthread.php?t=9028
@Knightshade
Progressive springs are softer under light load, and firmer under hard load.
http://my.is/forums/f126/f-sport-acc...prings-440927/
Info about aftermarket springs on oem shocks :
http://www.ft86club.com/forums/showthread.php?t=22473
I have this list until now :
Progressive Springs Rates
Eibach Pro-Kit
http://performance-suspension.eibach.com/
Eibach Sportline
H&R Sport Spring
H&R Super Sport Springs
http://www.hrsprings.com/
Tein H-Tech
http://www.tein.com/
Tein S-Tech
http://www.tein.com/RaceComp Tarmac
http://www.racecompengineering.com/
RS*R Super Down SUS
http://rs-r.com/lowering-springs/
B&G S2 Sport Springs
http://www.b-gsuspension.com
Racecomp Tarmac to be confirmed
"Predominantly" Linear Springs Rates
Hotchkis Sport
http://www.hotchkis.net/
Racecomp Yellow
Mach V
http://www.machv.com/
Swift sport to be confirmed
http://www.swiftsprings.net/products-sport_springs.html
Tanabe GF210
http://www.tanabe-usa.com
Linear in front and progressive in rear
TRD
No idea :
ST Sport
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 02-09-2013, 06:54 PM   #2
Mikepage
Mikepage's Avatar
I currently work on a list, i will share it with you soon guys.
Old 02-09-2013, 08:19 PM   #3
Mikepage
Mikepage's Avatar
update post 1
Old 02-09-2013, 08:28 PM   #4
jflogerzi
jflogerzi's Avatar
What about RCE Yellows
Old 02-09-2013, 08:30 PM   #5
Mikepage
Mikepage's Avatar
i don't know, am on it, am doing some research.
I think they don't specify it.
Old 02-09-2013, 09:19 PM   #6
jetlex
Drives: none
Tag - will be some good info!
jetlex is offline   Reply With Quote
Old 02-09-2013, 11:18 PM   #7
Squishy86
Squishy86's Avatar
Drives: Your Car
I know a progressive spring is really horrible to pair with a stock shock. Will a linear spring cause the stock shock to blow quicker?
Squishy86 is offline   Reply With Quote
Old 02-10-2013, 12:44 AM   #8
Mikepage
Mikepage's Avatar
Probably less than a progressive spring, let the company engineers reply to this question in detail.
Maybe the guys from Race Comp can help here, Andrew? Can you tell if your spring are linear?
Old 02-10-2013, 01:26 AM   #9
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Some of the springs out there are only progressive just to take up some initial drop and be captive, then the rate is linear.
uspspro is offline   Reply With Quote
Old 02-10-2013, 01:28 AM   #10
ft_sjo
Drives: GT86
I'd be extremely surprised if you find any linear aftermarket springs which aren't custom made.
The easy option is coilovers, but that opens up a big can of worms in itself.
Old 02-10-2013, 09:57 PM   #11
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
It's going to be difficult to make a spring that's completely linear, AND that lowers the car. If you just shorten up the spring and firm up the rate, then it won't be tight in the suspension at full droop. The result would be a spring that rattles every time the wheel drops into a hole.
To keep that from happening, you wind in some lower-rate coils that will be fully compressed (or "dead") when the car is at normal height. Then when the suspension goes to full droop, the spring will stay snug and won't rattle around. Some coilover suspension systems use a lighter-rate "helper" spring for the same purpose.
As you can see above, our springs have close-wound coils for a bit, then wider-spaced coils for the bulk of the spring travel. The effective rate that the suspension will see under normal use is linear, but the spring is not uniformly wound. Most, if not all, the aftermarket springs I have seen for this car use that design.
I guess that's a long way of getting to the point that it's not so simple as saying a spring is "progressive" or "linear."
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 02-10-2013, 09:59 PM   #12
Racecomp Engineering
Our springs are linear at normal ride height. There is a progressive section that kind of acts as a helper/tender spring but we wanted them to be as linear as possible.
EDIT: wow, Mach V Dan answered around the same time in a little more detail. Well put.
- Andrew
Old 02-10-2013, 10:02 PM   #13
Mikepage
Mikepage's Avatar
Thanks Dan for the explanation. Where i can put your springs into my list finally :P ?
Old 02-10-2013, 10:04 PM   #14
Mikepage
Mikepage's Avatar
- Andrew
Thanks to confirm Andrew, i will put your springs into the linear list definitively.
Front Spring Diameter Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 12-17-2012 12:06 PM
Best Spring Rate please help whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-30-2012 09:02 PM
Progressive snapshot Yruyur Scion FR-S / Toyota 86 GT86 General Forum 11 09-25-2012 12:31 AM
vibration after spring install? sajonf Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-30-2012 02:30 PM
Spring Rate Calculator yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-28-2012 11:31 AM
