Old 02-14-2014, 01:05 AM   #1
tracerit
Drives: '13 SSM BRZ Limited 6MT
AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok?
I have a Unichip and turned it off on Tuesday morning, drove ok that night. However on Wednesday night when I started the car it hesitated a bit, check engine light came on and I turned it off. Used my Torque app and discovered the P0102 code. Turns out Mass airflow Circuit Low. I checked the MAF and all hoses and it turned out ok. Cleared the code. Drove it to work.
Then tonight I used Torque to check the AFR during my drive. At an idle stop it's ~15, on throttle it's ~15 but when I let off throttle it'll jump up to 20.3, then back to ~15 when I come to a stop. Is this normal?
tracerit is offline   Reply With Quote
Old 02-14-2014, 01:18 AM   #2
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Short answer, yes, but i've been drinking and probably won't give a solid long answer. It's something to do with the limits of your sensor (20.3) and air passing through the engine when not under throttle.
Yay whiskey!
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 02-14-2014, 01:19 AM   #3
jflogerzi
jflogerzi's Avatar
20 with zero throttle is pretty normal. Best way to check AFR is start @ 2500RPM in 3rd. Do a pull WOT till red line. Whats your AFR there. Should be in the low to mid 11's
Old 02-14-2014, 05:17 AM   #4
zooki
Drives: waiting on a 2021...
When you let off the throttle the car cuts off the fuel to the motor. Your basically just pumping air through it while you decelerate.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 02-14-2014, 08:21 AM   #5
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
you do not want to have 15 AFR under WOT... not sure if that's what you're saying your seeing
86-tundra is offline   Reply With Quote
Old 02-14-2014, 09:50 AM   #6
mitosis
mitosis's Avatar
Drives: 2013 FR-S, 2008 Fit
Yeah I've noticed that under partial throttle the car usually stays around 14.5, so it's hard to tell what the OP means by "on throttle" ...WOT or not? As others have stated, when giving zero throttle and coasting while still in gear the AFR is technically infinity (some quantity of air / zero fuel = divide by zero error, aka infinity) so that 20-ish that you're seeing is just the max value the sensor is capable of.
mitosis is offline   Reply With Quote
Old 02-14-2014, 12:27 PM   #7
tracerit
it's not exactly 15, a bit under it. I was using the graph portion of Torque so i'll try again when I head to work and look at actual numbers while on cruise control to try and keep it consistent. it's not WOT btw, just a moderate amount of throttle? basically I don't drive aggressively is how I would describe my driving, I shift at 4k pretty much all the time.
Old 02-14-2014, 12:38 PM   #8
tracerit
didn't want to create a new thread for this but when I was checking tubing I noticed this small collection of fluid right on top of the engine. Not sure where it came from, any ideas?
Old 02-15-2014, 10:22 AM   #9
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
probably just some crap from outside got up there and pooled. no fluids travel up there from the car
IG-Joey_Soul
Old 02-15-2014, 11:51 AM   #10
tracerit
yeah it looks like maybe old rain water or moisture from the mornings when i think about it.
seems like the check engine light p0102 came from me turning the unichip on/off, so i'm thinking maybe it's the ECU accounting for the sudden change.
Old 02-15-2014, 11:59 AM   #11
86-tundra
Troll Hunter
86-tundra's Avatar
you need to go WOT for us to fully understand your issue. It's too hard to diagnose if you shift at 4k.
put it in 3rd, get low in the RPMS, and floor it. Just watch the AFR. Make sure it doesn't creep.
Old 02-15-2014, 12:44 PM   #12
jamesm
11-11.5 afr is pretty damn rich for an NA car. That's what I run under boost .
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
Throttle Response CamryDS Northern California 27 03-31-2015 03:35 AM
throttle dip? JDM FRS Issues | Warranty | Recalls / TSB 18 07-07-2013 03:50 AM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
