Old 07-19-2015, 03:25 PM   #1
6pack
6pack's Avatar
Drives: GT86
OBDII socket trouble
Hello everyone,
my OBDII socket is playing stupid. A recent (and simple) upgrade with EcuTek got us mad, the software could'n not find the OBDii signal. Often also my BT dongle doesn't connect.
Wiggling the plug at the end works, but it makes things worst in the long run.
It's obviously a hardware issue: the socket is flimsy to start with and some of the pins/contacts got some slack with the usage. On the solder side.
I need to rewire the socket or take some measure to secure the pins once and for all.
Any experience or tip on this?
How would you do it?
  • Go to Toyota? (least preferred solution)
  • Find a good car electric techie?
  • Hot glue on the contacts?
If I'm double posting I apologize, please direct me to the proper thread.
Thanks y'all
6pack is offline   Reply With Quote
Old 07-19-2015, 05:42 PM   #2
steve99
Originally Posted by 6pack View Post
Hello everyone,
Thanks y'all
yes the obd socket can be intermittent
if you can find and obd extension with thick pins it can sometimes solve your issues.
probably good car electrics guy will be cheaper.
Old 07-20-2015, 06:47 AM   #3
6pack
6pack's Avatar
Drives: GT86
...if you can find and obd extension with thick pins it can sometimes solve your issues.
The extension was my plan A, but not much improvement.
Maybe after I fix the socket to keep it safe...
Thanks though Steve
Old 07-20-2015, 08:01 AM   #4
vgi
Drives: frs
I'm curious if anyone else has connection problems after latest Ecutek update?
I am having issues with EcuTek dropping connection (during logging or flashing) after their recent update as well. On both of my laptops and on any port (one has 2 usb ports, the other one has 3 usb ports). For me though, it's always the cable, never the usb key.
I suspect they might have updated the usb drivers their soft uses and the new drivers are buggy. Or it could be my cable going bad and it's just a coincidence it happens at the same time I have updated my software with their latest revision.
I have sent a PM to EcuTek (since I couldn't find a support email on their web) a few days ago asking if I could get their previous built which was working well for me but so far haven't got a response. Seems like they use their account here just to make the same advertising post on all threads.
vgi is offline   Reply With Quote
Old 07-20-2015, 09:01 AM   #5
Calum
That Guy
Drives: 2013 asphalt FRS MT
One of these might help. I'm not sure if they have the correct one for our car, but it shouldn't be hard to make a mount for the one I linked.
[ame="http://www.amazon.com/Replacement-Diagnostic-Sockets-Compatible-Cadillac/dp/B00LKQACE2/ref=sr_1_1?ie=UTF8&qid=1437397290&sr=8-1&keywords=obd2+port"]Amazon.com: Replacement Female J1962 OBD II 2 Diagnostic System Housing w/ 16 Female Wire Sockets. Compatible with most GM, Buick, Cadillac, and some Chrysler, Jeep, and Ford vehicles: Automotive[/ame]
Old 07-20-2015, 06:51 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
Email the sales email address, it still gets seen by the same people.
I will try mine tomorrow and confirm if it's a software issue.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-21-2015, 12:54 AM   #7
6pack
6pack's Avatar
Drives: GT86
That is very possible but not in my case. My OBDII socket is been critical long time.
I use it with a Pivot gauge, a BT dongle (Torque) and the Ecutek: its connection is spotty all the time. I can see the pins receding when you insert the plug.
Originally Posted by Calum View Post
One of these might help. I'm not sure if they have the correct one for our car, but it shouldn't be hard to make a mount for the one I linked...
That is a good tip Calum, thanks. You've got me on the right path:
[ame="http://www.amazon.com/Replacement-Diagnostic-Housing-Sockets-Mitsubishi/dp/B00LKPRGKQ/ref=pd_sbs_263_3/180-5244200-7141456?ie=UTF8&refRID=1K1H0CD76JENTX6Q8NCS"]Amazon.com: Replacement Female J1962 OBD II 2 Diagnostic System Housing w/ 16 Female Wire Sockets. Hyundai, Mitsubishi, Kia, Mazda, Subaru: Automotive[/ame]
If I go with that it would be a good move to relocate the socket to an easier spot to reach all together.
obd2, obdii, pins, socket
Which LED bulb/socket? whip DIY (Do-It-Yourself) Guides 5 09-04-2014 02:44 AM
Socket Set MrMista Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-28-2013 03:21 PM
02 Sensor Socket Size? swift996 Engine, Exhaust, Transmission 6 08-19-2013 09:30 PM
Socket set and torque wrench Ty89m Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 07-29-2013 12:46 AM
Reading OBDII and CANBUS over OBDII-Bluetooth adapter? wparsons Electronics | Audio | NAV | Infotainment 8 06-12-2013 07:17 PM
