Old 07-17-2015, 10:31 PM   #1
Aegis3425
Drives: 2013 Asphalt FRS
What offset should I get?
Hello,
I'm pretty new to getting wheels and I was wondering what offset to get to make my wheel flush with my fender. I lowered my car about 1" and was aiming for 18 x 8.5/9.0 wheels. Do you guys have any suggestions?
Appreciate the help!
Aegis3425 is offline   Reply With Quote
Old 07-17-2015, 11:12 PM   #2
Fastbrew
Drives: 2014 Pearl White BRZ
http://www.ft86club.com/forums/showthread.php?t=7535
Here is a great start.
Fastbrew is offline   Reply With Quote
Old 07-17-2015, 11:18 PM   #3
Aegis3425
Yeah I took a look at that chart but I was a bit confused. It shows 2 offset numbers for a drop of 1". I was looking to go for a square set up, not quite sure which offset number to use.
Old 07-17-2015, 11:34 PM   #4
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Well that's the problem - the rear is "sunk" in more than the front by about 10mm on each side. So if you want both fenders to match you need rear spacers, which means new rear studs, which means dropping the rear hubs.
If you are going to put the stock wheels back on (for winter or whatever) then keep 48 or 43 et and get the spacers done.
And you really have to pick your wheel width. A 9 inch wheel et 35 will poke past the fender, an 8 inch wheel will not. Hence the chart.
Khyron686 is offline   Reply With Quote
Old 07-17-2015, 11:43 PM   #5
Aegis3425
I've decided to go with the 8.5 inch width. I'm ok with the rear being sunken in, just want the fronts to be flush with the fender. I also won't need to swap the wheels around because I live in California so no snow here.
Old 07-18-2015, 01:35 AM   #6
Fastbrew
By looking in the table in the thread I linked - there is a star for a perfect fit.
http://www.ft86club.com/forums/showthread.php?t=57214
Old 07-18-2015, 03:04 PM   #7
Khyron686
Yep, so 43 to 48 looks a good offset range to play with. This is 47 and seems pretty good (note the rear is totally different)
http://www.ft86club.com/forums/showthread.php?t=10436
Help with offset FRSBeginner Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 01-24-2015 02:35 PM
offset help mikltov Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 12-27-2014 03:40 AM
Offset TomT2411 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-28-2014 01:13 PM
205/55 16. 40 offset. Will they fit? Nourdmrolnmt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-02-2013 01:31 PM
What offset is legal? What offset provides most benefit? bdohazelnuts Tracking / Autocross / HPDE / Drifting 2 02-08-2013 01:32 PM
