Drives: Asphalt FR-S 2013
Help with offset
Hi everyone!
I'm thinking of purchasing ag f440 wheels in 19 x 8.5 front and 9.5 rear. I can't seem to figure out the offset that I want for them though! What do you all think is a good offset? Aim is to flush wheels to fender! I'm lowered on coils to a finger gap at this moment. Advice? Tip? Opinions? |
@swarb
I forgot to mention I have no access to a computer anymore so I can't use the wheel calculator hahaha |
don't use mobile site. go to a library. borrow a computer. buy a computer. buy a tablet.
Why when I can spend more on the car?! Hahaha
Thanks for the "help" anyway |
I like to eat!
Good luck finding tires. Selection will be quite Limited.
(There may be less than 5 people on this forum with 19" wheels on the 86) |
| The Following User Says Thank You to Pete156 For This Useful Post: | FRSBeginner (01-20-2015) |
I actually know a couple people rolling on 19s so tires aren't much of a problem :P
Just the offset on these wheels Brainstorming by looking through a bunch of pics with specs through my phone 👎 |
Drives:
I'm no wheel expert or anything so take this with a grain of salt, but wouldn't the offset be the same no matter what the diameter is? So an 18x9.5 +35 would be the same as a 19x9.5 +35? Going off of that assumption, you could just research cars that are running staggered fitments in 18's and get a feeling for what you like. I know there are at least a handful of guys running those sizes.
Remember
Drives: 2015 Asphalt
Perch clearance issues with wide wheels, add in larger diameters for possibly more perch clearance issues.
Anyway OP, I suggest asking in the "will this fit" thread stickied at the top.
This is my 17th car. Most fun so far!
#10 |
Drives: 2013 Firestorm FRS
#11 |
Drives: '13 UM86
Hey guys - I came across these Rota Torque 17x9 +30 wheels http://store.wheeldude.com/17x9-rota...00-e30-73.html and am strongly considering it. However, before I pull the trigger will these work with my current setup?
Stock suspension Stock top hat Eibach sportline springs drop (1.4") spc camber bolts
![]() JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport |
#12 |
Drives: '24 GR86
+40 or so is a good spot to start with 19s in those widths.
Offset is going to be the same for fitment +/- a few mm with larger diameter wheels simply because they will fill the fenders more with larger diameter wheels/tires. I'd say just go with 18s since you want a larger wheel but it's your car to do what you want with. 18s would just make life a lot easier.
| The Following User Says Thank You to TylerLieberman For This Useful Post: | FRSBeginner (01-22-2015) |
#13 |
I would go 18s but these come in 19s and up
![]() Got a 18x8 +35 square on raijins Atm |
#14 |
Drives: 2014 FR-S
for the fronts you need 40et as for rears i have 50et but I'm also 19x10.
| offset is everything | notFRS | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 24 | 04-11-2017 02:52 PM |
| offset help | mikltov | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 12-27-2014 03:40 AM |
| Offset | TomT2411 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-28-2014 01:13 PM |
| 205/55 16. 40 offset. Will they fit? | Nourdmrolnmt1 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 12-02-2013 01:31 PM |
| What offset is legal? What offset provides most benefit? | bdohazelnuts | Tracking / Autocross / HPDE / Drifting | 2 | 02-08-2013 01:32 PM |
