Old 09-28-2014, 11:14 AM   #1
TomT2411
TomT2411's Avatar
Drives: Bagged FRS
Offset
So right now I have stock wheels on my car and it says the offset is +48 and they tuck in the fender. Lets say if I get a wheel that is +43 and or +35 will it be out more past the fender because that's what I'm looking for a wheel that is not tucked in. So the higher the offset the wheel is going to be more into the fender right and lower numbers will be sticking out correct?
Thank you cause I am a little bit confused!
Check out my Instagram!
http://instagram.com/tomturrisi
Bagged FRS
TomT2411 is offline   Reply With Quote
Old 09-28-2014, 01:13 PM   #2
Phil_Marino
Drives: 2013 FRS (red)
You've got it right. Those numbers are millimeters, so a wheel with 43 offset will stick out 5 mm ( 0.2 inches) more than the stock wheel with 48 offset.
Phil_Marino is offline   Reply With Quote
offset is everything notFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 04-11-2017 02:52 PM
offset ??? van_fc3s Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-12-2014 02:38 PM
205/55 16. 40 offset. Will they fit? Nourdmrolnmt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-02-2013 01:31 PM
What offset is legal? What offset provides most benefit? bdohazelnuts Tracking / Autocross / HPDE / Drifting 2 02-08-2013 01:32 PM
Offset for GT vs. GTS giraffee AUSTRALIA 3 07-20-2012 12:30 AM
