Old 07-15-2015, 12:53 AM   #1
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Accidentally had a shop put in 75w140 for the MT fluid...
As the title says, put a much thicker gear oil than most people use. My question is, is it worth buying a better thinner oil and swapping it.
Is there any ill effects that could hurt the tranny?
I've heard mixed things, but pennzoil 75w90 and eneos 75w90 seem to be some of the highest rated gear oils for the trans
Thanks ahead of time
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 07-15-2015, 01:12 AM   #2
swarb
I don't know. Is your transmission worth it? Why not put corn oil in the engine? oil is oil right? Leave it in there and find out.
Old 07-15-2015, 01:43 AM   #3
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Is your car a purpose built racecar that sees elevated temperatures constantly and eats transmissions as a consumable?
No?
You should probably go to a thinner oil, as I doubt your bearings and gears are happy with something that thick.
Edit: Also make sure its not a GL-5!!!!!
Decay107 is offline   Reply With Quote
Old 07-15-2015, 01:50 AM   #4
humfrz
No?
I'll second that .......
humfrz
Old 07-15-2015, 01:54 AM   #5
Decay107
Decay107's Avatar
I'll just add in again so it cannot possibly be missed.
Make sure that oil is not a GL5 or you'll be fighting a corrosion problem on top of a lubrication problem!
The Following User Says Thank You to Decay107 For This Useful Post:
SlammedSilly (07-28-2015)
Old 07-15-2015, 02:18 AM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
^^By far the most important point in this thread.^^
Old 07-15-2015, 03:11 AM   #7
Aztec
Aztec's Avatar
No?
Thank you gents, I'll be swapping out the trans fluid tomorrow. Luckily it hasn't been more than day so no real damage has been done.
NEW CAR!🚨🏎️⛽
Old 07-15-2015, 07:14 AM   #8
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
I would consider switching over to Motul Gear 300 75w90. We've had great success with this fluid in 100s of customer cars over the years. This fluid gives you very smooth engagement coupled with full synthetic protection. Our Project BRZ which is a track and street car as well as our Spec86 Cup wheel to wheel race car get this in both the transmission and rear differential.
We never suggest anything that we don't use in our own vehicles and haven't tested ourselves.
You can purchase (4) Liters for $85 shipped through us as well. http://store.azpparts.com/fluids/motul-gear-300-75w90/
-mike
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
Ultramaroon (07-15-2015)
Brake pad and fluid install shop recommendation(south florida)? becauseracecar1 Southeast 3 04-21-2014 10:32 AM
Local shop selling Motul 300V, high end brake fluid, etc. for track? mike_ekim1024 Northern California 12 03-09-2014 02:08 PM
does anyone else accidentally press the buttons on the key fob while starting car? fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 19 04-14-2013 10:30 AM
Accidentally downshifted to first at 40mph slowbrz Scion FR-S / Toyota 86 GT86 General Forum 60 12-19-2012 11:33 PM
Accidentally blew the dash speakers bladesamurai Electronics | Audio | NAV | Infotainment 15 06-20-2012 09:25 AM
