Drives: '13 black BRZ MT
Accidentally downshifted to first at 40mph
is this bad? I tried downshifting to third but went too far left
Derp
how did you even get it into gear? i almost can't put it back in first unless i'm completely stopped...
| The Following 3 Users Say Thank You to lantsalot For This Useful Post: |
Drives: 2013 DGM BRZ Limited
You should be ok. 40mph shouldn't have revved the engine too much into the redline. Just don't make a habit of it.
| The Following User Says Thank You to rapidcars For This Useful Post: | Wolfking (12-17-2012) |
Drives: 2013 Subaru BRZ
Certainly could not be good.
Drives: Attitude
Not good. I did something similar on a right rand sweeper on some back roads and the only thing that happened was the rear stepped out and I fought to get control of the car; I felt it as soon as I let the clutch out a little bit and then in an instant the rear just snapped out. It happens, remember to push the clutch in and steer the car straight.
#6 | |
I Love custom Turbo kits
Drives: Limited BRZ
Drives: BRZ and NA
Did you push the clutch back in before you over-rev'd the engine? If so, you're safe. You probably just got a little extra wear on your transmission synchros by having 1st gear spin up that quickly.
This chart says that the max speed in first gear (at 7400 rpms) is 36 mph. If you were going faster than that and you let your engine over-rev, then you might have damaged something; probably your valves. http://media.caranddriver.com/files/...napoleon-1.pdf The best thing for you to do now is to simply drive your car and see if you notice and issues. If not, you're good to go. |
I remember seeing a yellow light but not sure what light this is. I quickly downshifted to 2nd but I should have gone up to 3rd.
how much mph can you go in first at 7500rpm? |
Drives: Asphalt AT
hopefully you double clutched
| The Following 3 Users Say Thank You to Asphalt~86 For This Useful Post: |
#10 |
Drives: Attitude
Slip light most likely, I'm more than confident you broke the tires loose. As Grim just said, it's around 36mph.
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Guff (12-17-2012) |
#11 |
Drives: Made In Japan
I don't know about others, but even if I try, I can't go downshift to 1st gear until I down to 5km/hr with my car. However I did once when I was doing 110km/hr to 3rd gear, that was when I first got my car and first driving manual.
| The Following User Says Thank You to TRD-FRS For This Useful Post: | lantsalot (12-17-2012) |
#12 |
Drives: '13 BRZ in WRB--let's mod!!!
It didn't blow up instantly? J/K...
It should be good, but problems may arise. Drive without the radio on & listen if anything sounds odd. Good luck... |
#13 |
Drives: 2013 FR-S Hot Lava
Anyone have a link to the chart showing what the max speed in each gear is?
Live to drive another day
#14 | ||
Drives: BRZ and NA
I posted a link to the chart several posts up. |
| Av Gas (low lead) fuel accidentally sold as Premium in NJ | Dadhawk | NY / NJ / CT / PA | 6 | 12-19-2012 12:05 PM |
| Accidentally blew the dash speakers | bladesamurai | Electronics | Audio | NAV | Infotainment | 15 | 06-20-2012 09:25 AM |
