Drives: Red subaru brz
Hey guys!
Specs: Garrett 50 trim turbo Tial Q BOV Tial 38mm external wastegate Greddy EBC Mishimoto FMIC Invidia N1 catback The car is running on 11-12 psi on 90 octane because im in AK and the highest grade they have is 90 smh So the issue is that every time i drive the car after the warm up, if i take it out of gear it dies, or if i sit and rev the engine after the warm up it dies as well, i talk to my tuner and sent him logs and he cant figure out whats going on! Checked for boost leaks and vac leaks nothing!!! Took apart the whole intake manifold and fuel system didnt find anything wrong except all the lose vac lines but even after clamping all of the lose vac lines still having issues. Help!!!!! |
Drives: 2015 Subaru BRZ
In for answers. Sorry I don't have them, but I hope you get things straightened out. Who made your exhaust manifold and down pipe?
Try putting this in the Forced Induction area.
NASA SpecE30 Racer
Picture of the engine bay. Where exactly is that Tial Q BOV located and how close to the MAF?
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | Guff (07-14-2017) |
11psi seems a bit excessive for 90 fuel.
What injectors.... and where is the BOV / MAF sensor? Is the MAF on a bend? Your tuner should be able to easily tell you what is wrong. If not then you should probably question your tuner and find another one...
This is the kind of question that no one here is going to be able to just give you the answer as to why its not working. We would need specifics on your turbo kit, fuel system, and logs... If you have aftermarket injectors there can be an obvious answer as to why the car stalls.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| The Following User Says Thank You to nelsmar For This Useful Post: | cdrazic93 (06-29-2015) |
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Does your BOV hang open at warm idle? I have the tial q as well and it would hang open at warm idle. MAF sensor location?
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#8 | |
Drives: Sprintex carbon fiber wide body
did you resolve this issue? I am seeing a similar issue.
#10 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Check for leaks around the MAF, check your MAP is in good working order, check your BOV is not hanging open. Those are all very common issues in the turbo frs world haha. |
| The Following User Says Thank You to go_a_way1 For This Useful Post: | leets4uc3 (07-14-2017) |
#11 |
I Love custom Turbo kits
Drives: Limited BRZ
If the tests don't reveal any mechanical problems and/or boost/vacuum leaks, it's time to talk to the tuner
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Guff (07-14-2017) |
#12 |
Drives: '13 BRZ
This issue can happen when the port injectors aren't scaled properly. Idle can be running DI or PI at different times. The stalling usually happens when you car switches from DI to PI at idle and the port injectors supply the wrong fueling. The car bogs and dies after.
Check your logs to see if your car is switching to port injection when it dies to confirm the issue. If so, it can be fixed via proper port injector scaling. |
#13 | ||
Cool. I will be doing a smoke test today so hopefully I find something. I am also getting a hard start. Cranks for a while before starting. Yesterday it wouldn't start at all after it stalled. Also, it happens more as the temperature goes up. I was thinking of checking out the cam and crank position sensors too. |
#14 | |
Drives: Track preped NA FRS
| Tags |
| brz, frs brz forged wheels, garrett, tial, turbo |
| Idle issue? | yayforaddison | Issues | Warranty | Recalls / TSB | 891 | 07-14-2016 10:42 AM |
| Another Idle Issue? | amacadam | Issues | Warranty | Recalls / TSB | 1 | 11-04-2014 05:35 AM |
| Idle issue when driving | carlossanchez89 | Software Tuning | 1 | 02-16-2014 12:52 PM |
| Possible Idle Issue???? Help please | soontobrz | Issues | Warranty | Recalls / TSB | 2 | 07-08-2013 07:34 PM |
| Idle issue | scioneric | CANADA | 23 | 08-24-2012 01:40 AM |
