Old 07-08-2013, 02:24 AM   #1
soontobrz
Drives: DGM BRZ
Possible Idle Issue???? Help please
I dont know if its just me or not but it seems my brz idles really poorly and jumps around a a lot. i know about the compressor kicking in but it seems really frequent. let me know your thoughts
soontobrz is offline   Reply With Quote
Old 07-08-2013, 07:26 PM   #2
chuchutrain
Drives: Firestorm
usually when i'm coming to a stop and the engines dropping back to idle it'll dip extra low then go back to normal. is that what you're getting?
chuchutrain is offline   Reply With Quote
Old 07-08-2013, 07:34 PM   #3
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Everyone I know with these cars has similar issues, even after the recent update/fix from the dealership (there are many threads in this forum covering it). Coming to a stop the idle drops low, car shudders, etc. Fluctuation in RPM/vibration at idle, etc.
Resetting the ECU by pulling the negative battery terminal for ten minutes did make some improvements on my car the last time it happened to me when it was stock, but in my experience it eventually comes back.
I recently purchased Visconti's stage1 tune and this has solved the issue completely for me. It's my understanding most aftermarket tunes will resolve this. The Visconti tune was the best money I've spent on the car without question as far as smoothness/drivability/power. If you can afford it, I'd recommend it.
Nightbringer is offline   Reply With Quote
Unofficial - CEL/SL/Idle Issue List for FR-S/BRZ Owners eurospeed Issues | Warranty | Recalls / TSB 3105 05-06-2024 06:47 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Injen Idle Issue? ozne99 Engine, Exhaust, Transmission 10 04-14-2013 10:27 PM
Idle issue question Nitesh31 Issues | Warranty | Recalls / TSB 9 09-28-2012 10:04 PM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
