Old 06-29-2015, 06:15 AM   #1
Aalyluvsjdm
Drives: Red subaru brz
Exclamation Brz turbo idle issue
Hey guys!
Specs:
Garrett 50 trim turbo
Tial Q BOV
Tial 38mm external wastegate
Greddy EBC
Mishimoto FMIC
Invidia N1 catback
The car is running on 11-12 psi on 90 octane because im in AK and the highest grade they have is 90 smh
So the issue is that every time i drive the car after the warm up, if i take it out of gear it dies, or if i sit and rev the engine after the warm up it dies as well, i talk to my tuner and sent him logs and he cant figure out whats going on!
Checked for boost leaks and vac leaks nothing!!! Took apart the whole intake manifold and fuel system didnt find anything wrong except all the lose vac lines but even after clamping all of the lose vac lines still having issues.
Help!!!!!
Aalyluvsjdm is offline   Reply With Quote
Old 06-29-2015, 07:13 AM   #2
IBill4You
Drives: 2015 Subaru BRZ
In for answers. Sorry I don't have them, but I hope you get things straightened out. Who made your exhaust manifold and down pipe?
IBill4You is offline   Reply With Quote
Old 06-29-2015, 10:08 AM   #3
fika84
fika84's Avatar
Try putting this in the Forced Induction area.
fika84 is offline   Reply With Quote
Old 06-29-2015, 11:37 AM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Picture of the engine bay. Where exactly is that Tial Q BOV located and how close to the MAF?
Guff (07-14-2017)
Old 06-29-2015, 03:01 PM   #5
FirestormFRS
11psi seems a bit excessive for 90 fuel.
FirestormFRS is offline   Reply With Quote
Old 06-29-2015, 03:05 PM   #6
nelsmar
What injectors.... and where is the BOV / MAF sensor? Is the MAF on a bend? Your tuner should be able to easily tell you what is wrong. If not then you should probably question your tuner and find another one...
This is the kind of question that no one here is going to be able to just give you the answer as to why its not working. We would need specifics on your turbo kit, fuel system, and logs... If you have aftermarket injectors there can be an obvious answer as to why the car stalls.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
cdrazic93 (06-29-2015)
Old 06-29-2015, 04:56 PM   #7
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Does your BOV hang open at warm idle? I have the tial q as well and it would hang open at warm idle. MAF sensor location?
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 06-29-2015, 05:36 PM   #8
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Originally Posted by Aalyluvsjdm View Post
Hey guys!
Specs:
Tial Q BOV
Greddy EBC
Mishimoto FMIC
Invidia N1 catback
Help!!!!!
Did you recently install a light weight crank pulley and/or a lightened flywheel? My idle went to shiz after I lightened the rotational mass on the crank. If that's what happened to yours, your tuner will need to compensate
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 07-14-2017, 09:43 AM   #9
leets4uc3
Drives: Sprintex carbon fiber wide body
did you resolve this issue? I am seeing a similar issue.
leets4uc3 is offline   Reply With Quote
Old 07-14-2017, 11:16 AM   #10
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Check for leaks around the MAF, check your MAP is in good working order, check your BOV is not hanging open. Those are all very common issues in the turbo frs world haha.
leets4uc3 (07-14-2017)
Old 07-14-2017, 12:28 PM   #11
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
If the tests don't reveal any mechanical problems and/or boost/vacuum leaks, it's time to talk to the tuner
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Guff (07-14-2017)
Old 07-14-2017, 12:47 PM   #12
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
This issue can happen when the port injectors aren't scaled properly. Idle can be running DI or PI at different times. The stalling usually happens when you car switches from DI to PI at idle and the port injectors supply the wrong fueling. The car bogs and dies after.
Check your logs to see if your car is switching to port injection when it dies to confirm the issue. If so, it can be fixed via proper port injector scaling.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 07-14-2017, 01:40 PM   #13
leets4uc3
Cool. I will be doing a smoke test today so hopefully I find something. I am also getting a hard start. Cranks for a while before starting. Yesterday it wouldn't start at all after it stalled. Also, it happens more as the temperature goes up. I was thinking of checking out the cam and crank position sensors too.
Old 07-14-2017, 02:00 PM   #14
Icecreamtruk
Drives: Track preped NA FRS
If you have a cam position sensor trouble you would have a code show up with the trouble, either one from (P0016 to P0019, P0016 is the most common one as that is on passanger side, where most of the trapped heat is and damage things over time). If you dont have this problems I wouldnt be looking for cam troubles just yet. Get logs going, its the easiest way to find out what is wrong. If you can interpret them or pull conclusions from them, post them here, and Im sure some people would be glad to help.
Icecreamtruk is offline   Reply With Quote
brz, frs brz forged wheels, garrett, tial, turbo
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
Another Idle Issue? amacadam Issues | Warranty | Recalls / TSB 1 11-04-2014 05:35 AM
Idle issue when driving carlossanchez89 Software Tuning 1 02-16-2014 12:52 PM
Possible Idle Issue???? Help please soontobrz Issues | Warranty | Recalls / TSB 2 07-08-2013 07:34 PM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
