Old 06-05-2015, 12:52 AM   #1
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Alignment issues?
Hey guys,
FR-S seems to lose alignment a week or two after it had been re-aligned. This is third time. Daily driven, not abused at all. All stock.
I will take it in for alignment, 2hrs or so later, come pick it up, drive it a week or two, then it pulls to right (iirc). Then I repeat the process of taking it in again every 3 weeks ($100/visit) or so. This is gonna take its toll on my wallet. Tires @ 90%+ thread, brand new. No rim wear/deformation.
Anything I can check or that you guys would recommend/have had similar issue?
Thanks.
~Packo
Packofcrows is offline   Reply With Quote
Old 06-05-2015, 01:02 AM   #2
swarb
Blown shock or bad wheel balance can be a possibility. Air pressure also.
Old 06-05-2015, 01:32 AM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Packofcrows View Post
Hey guys,
Thanks.
~Packo
I agree on the shocks being an issue or the wheel balance being an issue but not tire pressure because normally tpms can detect a dangerous variation. I would honestly go to a reputable Toyota dealer and say the car is continually losing alignment, it could probably even be a defective alignment rack or them not aligning to spec. Stop wasting money on alignments because the problem keeps reappearing go to a dealer that knows what there doing.
Old 06-05-2015, 02:22 AM   #4
ryoma
ryoma's Avatar
talk to your alignment shop about this. if it's a reputable shop, they should be able to figure it out and won't charge you if you have just recently gotten an alignment even more so if you've gone there multiple times within a short period.
Old 06-05-2015, 07:34 AM   #5
wparsons
wparsons's Avatar
What setting(s) is drifting on the alignment? Are they actually showing you the specs before/after, or just saying they fixed it?
The only adjustments stock are toe, and front toe is VERY unlikely to "slip" unless you hit something, which really only leaves the rear toe. It shouldn't be slipping at all without a major impact or serious abuse though.
It could also be tire pressure, the TPMS system lets you have a ~5psi variance before it turns on the light and that's enough of a difference that it could be felt like this.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
FRSBRZGT86FAN (06-05-2015)
Old 06-05-2015, 08:13 AM   #6
FRSBRZGT86FAN
But man, 5 psi under for 3 weeks+ someone probably purposely leaked air out of the tires
Rear camber assymmetry and alignment issues ofuts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 02-02-2015 12:46 PM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
Alignment issues?? 4pokguy CANADA 4 02-18-2014 12:43 PM
Alignment issues Doborder Issues | Warranty | Recalls / TSB 6 10-13-2013 10:41 AM
DIY Alignment FRSFirestorm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 10-03-2013 05:29 PM
