Old 10-12-2013, 03:13 PM   #1
Doborder
Godzilla Konvert
Doborder's Avatar
Drives: DMG BRZ Limited 6MT 2013
Alignment issues
I been using this car as a DD for about 5 months
I hit some big pot hole and had to replace the bearing
So I got the car realigned after that.
Ever since then the car cannot hold its alignment
I have taken it back to the alignment shop 3 times this month
And every time they put it on the rack the alignment is
Completely off. I don't track the car. I use it for a dd
Not even spirited driving. The dealer was no help. They are the ones that actually replaced the bearings
The car doesn't pull that badly anymore... Or maybe I've just gotten
Use to it.
Question for people that actually track it?
Is it holding the alignment? If it can't do it on a dd
I wonder how it does when you actually push the car
Thanks
2013 Subaru BRZ Limited MT (DMG)
CO>CA Cartel
Doborder is offline   Reply With Quote
Old 10-12-2013, 05:50 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Use to it.
Thanks
What specs are being thrown off? toe? camber? by how much?
Old 10-12-2013, 05:51 PM   #3
White64Goat
What bearing? Wheel bearing? If it won't hold alignment, something is wrong and you need to find out what it is before you have a catastrophic failure.
Old 10-12-2013, 08:44 PM   #4
Ozzman
Drives: old
Post up the before and after readings for the alignment.
Ozzman is offline   Reply With Quote
Old 10-13-2013, 12:40 AM   #5
Doborder
Godzilla Konvert
Doborder's Avatar
Will do
Wheel bearing was replaced by the dealership
CO>CA Cartel
Old 10-13-2013, 07:42 AM   #6
fistpoint
Drives: Supercharged Golf Cart
Tie rod maybe?
fistpoint is offline   Reply With Quote
Old 10-13-2013, 10:41 AM   #7
Suberman
Drives: Subaru BRZ Sport Tech Satin White
The explanation you've been given is pure BS.
Once the alignment is completed CORRECTLY nothing can move so the alignment can't mysteriously alter.
Alignment is fixed by the suspension bolts.
Bushing wear or component damage are the causes of alignment variation. If done properly the alignment settings themselves CANNOT MOVE.
Your alignment shop is incompetent.
Probably you have some as yet I identified suspension damage due to the pothole hit. I'd guess a tie rod or ball joint as been bent or flattened.
Suberman is offline   Reply With Quote
DIY Alignment FRSFirestorm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 10-03-2013 05:29 PM
alignment dori. NY / NJ / CT / PA 10 04-02-2013 03:57 PM
Anyone do their own alignment? TemeCal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-09-2012 11:36 PM
DIY alignment dsgerbc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-17-2012 11:41 AM
where to get alignment? FML Hawaii 2 08-08-2012 01:36 AM
