Old 01-19-2015, 01:05 PM   #1
ofuts
Drives: 2013 Toyota 86 MT
Rear camber assymmetry and alignment issues
Hi everyone,
I am having some issues i can not solve till now, would appriciate some help and suggestions.
I am lowered about 1,5 inch with HKS Hipermax 4 GT coilovers, 18*9,5 +45 Kojins and 255/35/18 Yokohama Neovas at all corners.
My alignment values are like this:
Toe: L R
F 0,00 -0,1 (-0,1)
R 0,05 0,05 (0,1)
Camber:
F -1,6 -1,7
R -1,6 -2,6
Caster: 6,3 -5,1
Thrust angle: -0,0
As you can see my problem is the assymmetric rear camber, does anyone have an idea why that happened?
I will get LCAs to fix it but i just want to know how it is possible. Worried about if i got a crashed car.
My other issue is, my alignment is off every time i check it (every month, this is the third time), and i havent been to track or havent driven in really bad roads. Front right cambers were -1,6/-1,6, rear cambers were -1,5/-2,5, front toes were -0,05, rear toes were 0,1. Car had alwayes been pulling to right after i got the coilovers, it is even worse now.
Do you think that caster difference is a big problem? Is there a way to fix it? And do you think it is the reason that car is always pulling to right or getting alignment off?
Thanks in advance
ofuts is offline   Reply With Quote
Old 01-19-2015, 05:10 PM   #2
wparsons
wparsons's Avatar
Caster alone will not make the car pull in a straight line.
Seeing cross camber out like that isn't uncommon, definitely isn't proof the car was crashed.
Was the alignment done with you sitting in the car? How close is the ride height on both sides (front right compared to front left, and rear right compared to rear left)? If the left rear is sitting higher, it will definitely have less camber.
flickr
Old 01-19-2015, 06:22 PM   #3
cjd
cjd's Avatar
Drives: 2017 BRZ
I recall reading somewhere or other that the rear subframe can sometimes be secured off-center enough to cause something like this (certainly, Whiteline likes to point out that their insert setup can help.)
Old 01-19-2015, 07:19 PM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Mine was pretty far off after lowering as well. I think I was -1.4 L / -2.2 R. This was also after I had White line rear subframe bushings installed. I have seen a few others post with rear camber off that much as well
Old 01-19-2015, 08:47 PM   #5
bfrank1972
Drives: 2013 FR-S Argento
Very common, not a big deal, LCA's will fix your problem
bfrank1972 is offline   Reply With Quote
Old 01-19-2015, 11:06 PM   #6
YouShallKnow
Drives: Man
Send a message via ICQ to YouShallKnow Send a message via AIM to YouShallKnow Send a message via Yahoo to YouShallKnow
Just got mine aligned today at West End and my rear was similar.
I have about a 1.5" drop with B6's and Swift Sport FR-S springs, my rear camber was like -2.2 and -2.7.
And I got my FR-S new.
YouShallKnow is offline   Reply With Quote
Old 01-19-2015, 11:49 PM   #7
08stiguy
08stiguy's Avatar
Drives:
Pm'd you
08stiguy is offline   Reply With Quote
Old 01-20-2015, 06:38 AM   #8
ofuts
I was not sitting in the car when alignment was made. Yes, left rear is about 8mm higher than right, so probably thats the reason, but still surprised 8mm can effect 1 degree. Ahh, shouldnt have belived the techs words Thanks for the reminder.
Anyway, do you think this might be the reason car is pulling to right? or alignment being off frequently?
Old 01-20-2015, 09:15 AM   #9
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Rear subframe needs to be shifted if you want to even it out. Lots of threads on this. 8mm will not make that much of a difference. Common issue.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 01-20-2015, 09:38 AM   #10
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Still not buying that argument. Shifting the rear subframe should* do very little to effect camber. ALL the suspension arms are connected to the subframe, shifting it left will just change the relationship to the body, no suspension arms will change relative to each other. The only reason I see to move the rear subframe is if the front and rear are not lined up to each other.
*shifting the subframe will slightly alter the angle of the rear shocks, thus changing the motion ratios slightly. I have not done the math, so can't comment on how much the change is, but it isn't likely to be significant enough to raise or lower the car, and with no change in ride height there is no change in camber.
celica73 is offline   Reply With Quote
The Following User Says Thank You to celica73 For This Useful Post:
wparsons (01-20-2015)
Old 01-20-2015, 10:37 AM   #11
Thorpedo
The SquadWhisperer
Heh, you're absolutely right. I bought into the bad info listed in the other threads and didn't think critically about it! Thanks for bringing that up.
Oddly enough I just removed the entire rear suspension last night. I did notice that a lot of the bolt holes in the subframe/bushings are large enough that there is a fair amount of "play" when the bolts are loose. Say if the upper control arm had inward force on it when it was tightened and the lower had outward force I could see it making a fair amount of difference in camber. Does this make sense?
Old 01-20-2015, 10:59 AM   #12
wparsons
wparsons's Avatar
Shifting the subframe can change toe readings since the toe is measured relative to the body, not the subframe, and also the thrust angle at the rear, but not camber.
You might get some camber change by applying inward or outward force when torquing the pivot bolts, how much I'm not sure.
Get it aligned with you in the drivers seat, I bet that 8mm difference is almost gone with your weight in it.
My car lowered 1" (swift sport springs) has -2.1* in the rear (cross camber is dead on with me in the car), no clue what it was at before installing the springs. I doubt you're getting 1* from 8mm difference in height though.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
ofuts (02-01-2015)
Old 01-26-2015, 01:13 AM   #13
DavidBob
DavidBob's Avatar
Drives: 2013 WRB BRZ
Quick question, I just bought LCA's because my rear camber isn't even. I read somewhere on the forum before that I will have to get adjustable toe arms too is that true? Will I need them to zero out my toe? (its zero'd out now just on coilovers) Anything info would help, thanks!
-Dave
DavidBob is offline   Reply With Quote
Old 01-26-2015, 01:16 AM   #14
finch1750
finch1750's Avatar
-Dave
It depends how much toe gets added based on your camber (and ride height maybe?). I'm at around -2 all around lowered 1" and the stock toe arms provided enough adjustment.
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
Does toe affect camber in the rear? More camber on one side after alignment shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-30-2014 09:37 AM
WTB: caster/camber plates - Or rear suspension alignment pieces STS-V Want-To-Buy Requests 0 06-27-2014 09:24 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Rear Camber/Alignment Question anewprelusion Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-25-2013 11:39 PM
