DIY alignment - quick way to set alignment while new suspension settles?
Hi all,
Quick questions for those that have installed coilovers on their own: How have you gone about setting your alignment while the suspension settles in? I'm thinking that getting an alignment right after installation seems like a waste but at the same time I would like toe to be within reason so that it's not dangerous to drive around / eat away at the tires excessively. I've seen the string method - are there any alternatives to achieve a "safe" alignment? Cheers.
Because compromise ®
Drives: Red Herring
I'm thinking not getting an alignment is a waste. Why would you compromise on such an important part of your car?
Turning is for Nerds
Drives: 35 characters is not enough
I measured each adjustable point that I removed/loosened/touched with a set of calipers and made sure to match those after installing my coilovers. When installing the coilovers I made sure to bias any loose fitting part to the same degree on each side (for example the strut tower bolts have a good amount of free play, I made sure to push them inwards and back on each side before tightening). Doing this got me within a few percent of the factory setup.
I'd still recommend getting a proper alignment within a week, unless you hate your tires. |
@Captain Snooze to be clear, I'm super anal about alignments - as I mentioned in Op, it's the initial first week or so of alignment settling post coilover install that seems to be wasteful to align right at install.
@Decay107 how did you compensate for changes in toe given drop in height/change in camber?
Drives: Yes
Find a shop who is willing to fix the alignment after the springs settle at no extra charge. Or do the Firestone lifetime alignment deal
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#6 | |
Basic outline here, http://www.hotrod.com/how-to/chassis...ignment-guide/ The need to adjust depends on how much you drive while waiting for it to settle. I did not notice a significant change in toe upon installing my setup and didn't bother changing it, but I did not deviate very far from factory ride height. If you want to settle your suspension quickly, take the car over a few speed bumps.
#7 | |
Drives: 2017 BRZ
![]() FWIW I've done the string method on a previous car (my wife's, after I had to replace the front subframe after the car curbed on black ice) and it turned out quite accurate - though of course that was not on a setup with adjustable ride height, so I was only tweaking camber and toe. The only thing I was never able to do was get the steering centered - otherwise the shop we took it to said it was within their normal tolerance (but they DID get the wheel centered...) C |
| WTB: caster/camber plates - Or rear suspension alignment pieces | STS-V | Want-To-Buy Requests | 0 | 06-27-2014 09:24 AM |
| Need Serious Alignment Check, Suspension Damage? | Staf00 | Southern California | 6 | 05-29-2014 11:49 PM |
| anyone know of a quick and cheap alignment shop in SFV | suboobaru | Southern California | 6 | 02-19-2014 01:17 PM |
| AJ USA Inc. Suspension, Alignment kit, Wheel spacers | AJUSA.com | Brakes, Suspension, Chassis | 16 | 12-06-2013 01:57 PM |
| Clanking from Rear Suspension After Alignment(w/ KW V3, Cusco LCA, Whiteline Toe Arm) | Figo | Issues | Warranty | Recalls / TSB | 29 | 10-29-2013 06:09 PM |
