Old 05-22-2015, 07:26 PM   #1
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Review: Diode Dynamic FRS Always-On Module
I recently purchased the Diode Dynamics FRS Always-On Module.
It was like roughly 40 dollars and it's pretty high quality.
The package came with a sticker, the module, shipping stuff, and some instructions.
To Install....
First Pop the hood and locate one of the headlight plugs and unplug it. I chose to do it on the driver side.
Connect one of the module ends to the headlight wire. There is only one way it will fit.
Connect the other end to the car.
Turn on your head lights.
The only problem I had was taking off the plug because it was pretty tight. The only confusion I had was I didn't know which way to turn to increase/lower brightness but once you start turning it you'll find out.
Overall, high quality product. 10/10 would buy again.
N1rve
Old 05-22-2015, 07:47 PM   #2
ryoma
ryoma's Avatar
oh, didn't realize the FRS and BRZ modules were different. I really like the FRS module. For my BRZ, I had to connect behind both headlights and had to run a wire from the fuse box, and between both headlights. It looks kind of lame with a wire coming out of the fusebox even though I tried tucking the wire away as best as I could, lol
Old 05-22-2015, 08:13 PM   #3
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Is this only for the monogram series?
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 05-22-2015, 08:21 PM   #4
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
I was considering this purchase... only necessary to plug in on one side?
asdf is offline   Reply With Quote
Old 05-22-2015, 08:33 PM   #5
N1rve
N1rve's Avatar
Should work for 10 series and RS 1.0 too
Yes.
N1rve
Old 05-22-2015, 08:38 PM   #6
86geek
86geek's Avatar
Yes.
I don't own a monogram or RS 1.0. So it can't work with just a base line FRS.
Old 05-22-2015, 09:12 PM   #7
N1rve
N1rve's Avatar
The mod is to light you the DRL on the JDM headlights lol
N1rve
Old 05-22-2015, 10:41 PM   #8
86geek
86geek's Avatar
Hahaha!
Old 05-23-2015, 04:11 AM   #9
N1rve
N1rve's Avatar
So I just found out that it can't dim... not sure why.
N1rve
Old 05-23-2015, 11:56 PM   #10
Sharpe978
Guest
Posts: n/a
Where can i find the FRS mod on their website? All i can find is the always on mod for the BRZ.
Old 05-24-2015, 04:27 AM   #11
mush
mush's Avatar
it looks like u did the drivers side...
mine came last week on monday and it didnt work, theyre sending a new module...
Old 05-24-2015, 02:57 PM   #12
kbye
kbye's Avatar
Drives: 2014 FR-S
Can you elaborate? Was it stuck on a single brightness setting? Or it doesn't dim brightness when switching from daytime to low-beam?
kbye is offline   Reply With Quote
Old 05-24-2015, 06:06 PM   #13
N1rve
N1rve's Avatar
Yeah... I'm not sure why they took it down. You can find it here....
http://www.fteightysix.com/appearanc...series-models/
Oops, I mix up driver and passenger
What was wrong with yours?
It's stuck on max brightness. I was at an 86 meet and when we tried adjusting it, it didn't make any difference. I sent them an E-mail.
N1rve
Old 05-25-2015, 02:18 PM   #14
mush
mush's Avatar
simply didnt work, drl didnt come on with the headlight
Help!! Diode Dynamic drls are melting?? Vincenttam Cosmetic Modification (Interior/Exterior/Lighting) 51 07-10-2015 10:49 AM
Complete set of Diode Dynamic LED lights from my BRZ kthrash Exterior Parts (Aero, Lighting, Etc.) 0 04-02-2015 11:53 AM
I got some diode dynamic lighting for my car!! Vincenttam Cosmetic Modification (Interior/Exterior/Lighting) 35 03-27-2015 01:58 PM
Diode Dynamic LED blow $400 fuse... balla_08 Cosmetic Modification (Interior/Exterior/Lighting) 12 04-18-2014 08:33 PM
Anyone use diode dynamic fog lights with HiD? KamakazeProject Cosmetic Modification (Interior/Exterior/Lighting) 7 01-24-2014 03:41 AM
