Old 04-27-2015, 06:45 PM   #1
DieselDog
Shift it or lose it
DieselDog's Avatar
Drives: 2014 FRS, 2003 Celica GT
Lowering and Alignment Question
I installed the Eibach Sportline kit in my FRS.
Now besides the springs everything else is stock.
To get my alignment in spec for proper Camber, Caster and Toe
I was just going to get the SPC camber bolts and arms as I don't need a huge amount of adjustment and I'm cheap.
My question is do I really need these extra parts to get the alignment in spec?
Also what are the acceptable limits for these 3 measurements that Scion recommends?
Any help is greatly appreciated . Thanks!
DieselDog is offline   Reply With Quote
Old 04-27-2015, 06:53 PM   #2
gramicci101
Off Topic
What camber and toe numbers are you looking to get from an alignment?
Old 04-27-2015, 08:45 PM   #3
DieselDog
Shift it or lose it
DieselDog's Avatar
Just getting back to factory specs or better.
Balanced handling and tire wear.
Old 04-27-2015, 09:10 PM   #4
wparsons
wparsons's Avatar
You'll need LCA's to get rear camber back in spec, front should already be ok.
If you want better handling, add camber bolts up front and max out the negative camber, with zero toe.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
DieselDog (04-28-2015)
Old 04-28-2015, 03:05 PM   #5
DieselDog
Shift it or lose it
DieselDog's Avatar
Anyone else have some input on this? Im looking for exact measurement values.
Old 04-28-2015, 03:16 PM   #6
gramicci101
Off Topic
Here are the factory specs.
The issue lies in that you'll gain a fair amount of negative camber just from the lowering springs. I have RCE Yellows and my rear camber is at -2, without any LCAs or adjustment bushings. Your Sportlines go lower, so you'll probably be around -2 to -2.5 in the rear. If you want to go anywhere other than what the springs get you, you will need LCAs.
In the front, I used camber bolts in the upper hole set to maximum camber, and ended up with -1.7. I could probably turn the bolts the other way and take the camber back down to OEM spec.
Next question is why do you want to go back to OEM spec vs. a more performance-oriented alignment?
Old 04-28-2015, 03:33 PM   #7
wparsons
wparsons's Avatar
Here's my 2 cents because you want an exact set of figures and not the factory ranges (which are huge).
front: 0 toe, -1* to -1.5* camber (max out camber bolts, make sure it's even side to side)
rear: ~1/16" total toe in, -0.5* to -1* camber, set based on how much front camber you can get.
You're going to need parts to adjust camber at both ends since camber isn't adjustable at all in stock form.
flickr
Old 04-28-2015, 04:38 PM   #8
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
Ditto what he said. I lowered my car on Tein Monosports and set my suspension to:
Front
> Camber: -2.8 degrees
> Toe: 0
Rear
> Camber: -2.0 degrees
> Toe: 1/16th toe in
It handles so well now. Stable and it turns in easily, making it feel very agile.
Camber is a bit excessive for a daily driven car so I recommend -2.0 degrees up front for you and -1.4 degrees in the back.
sittinSideways is offline   Reply With Quote
Old 04-28-2015, 04:46 PM   #9
Gunman
Drives: 2019 Mazda Miata RF
With 1" drop on Hotchkis springs, and OEM camber bolts maxed out, I got -1° camber up front. No new parts in the rear, and i have -2° camber. Toe is 0 up front, and rear.
Gunman is offline   Reply With Quote
Old 04-28-2015, 05:08 PM   #10
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
SPC Arms in the rear and Bolts in the front are what we use for any lowered cars. We also use these on our Spec86 Racecar and Project BRZ Track/Street car. Probably installed 50+ sets and no issues IF you have an aligner/installer who knows how to properly tighten down the bolts so they don't move.
-mike
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
Old 04-28-2015, 05:15 PM   #11
DieselDog
Shift it or lose it
DieselDog's Avatar
I don't necessarily want to go back to OEM specs I just want them so I have a comparative.
I do daily drive this and tire wear is a bit of a concern as they are about $300 a tire here and my wheels are staggered so no rotating to reduce uneven wear.
I don't need it to handle like a track car as I don't use it for that.
Just trying to see how I want to set it up. First time lowering a car and I want to do it right without wasting money on parts I don't really need.
Old 04-28-2015, 05:22 PM   #12
DieselDog
Shift it or lose it
DieselDog's Avatar
Thanks again for everyones input. I think I will be buying the SPC bolts and arms just to get everything to reasonable specs.
Old 04-28-2015, 05:27 PM   #13
gramicci101
Off Topic
Pick up some SPC camber bolts and install them in the bottom strut hole on the front. That way you'll have some front adjustability.
Then go get an alignment and see where you're at. You want the front to be a hair more than the rear. E.g., -1.5f/-1r or -2f/-1.5r. That kind of thing. Either one of those pairs of numbers will be fine, without having uneven tire wear. Keep the front at 0 toe-in, have the rear toed in to ~1/32 to 1/16 each side.
This will give you an agile alignment that is reasonably stable on the highway and conservative on tire wear. You will possibly need rear LCAs, depending on what your rear camber is after the springs.
All of these numbers are changeable to achieve different purposes for the car. Different people will recommend different settings, but this is a good baseline to start from.
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 04-28-2015, 09:52 PM   #14
wparsons
wparsons's Avatar
^^ top hole, not bottom hole. You'll get more adjustment range in the top hole.
flickr
For anyone not getting an alignment after lowering... wparsons Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-15-2014 11:13 PM
Alignment question? cjsporl1996 Tracking / Autocross / HPDE / Drifting 13 05-12-2014 04:00 PM
Alignment After Lowering mjsivee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-11-2013 11:12 AM
Proper Alignment - Post Eibach Pro Lowering Thatruth2001 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-10-2012 01:48 AM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 02:57 PM
