Old 07-14-2014, 01:55 PM   #1
wparsons
wparsons's Avatar
For anyone not getting an alignment after lowering...
After just springs and camber bolts maxed out, my car was sitting at...
Camber
FL: -1.47
FR: -1.39
RL: -2.07
RR: -2.11
Toe
F: 1/4" out
R: 1/2" in
I hadn't touched anything in the rear other than installing the springs, and up front I just put the whiteline bolts in along with the springs up front.
Specs after are -2* up front, -2.1* in the rear, 0 toe up front and 1/16" rear toe. The alignment guy I went to wanted more camber up front vs less in the rear, so I didn't actually need LCA's at all, and he got more up front with just a slight bit of slotting on the stock struts (plus the camber bolts).
The car drives totally differently now, can't wait to get it out on a track again. All the push I was fighting should be totally gone now!
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Racecomp Engineering (07-14-2014)
Old 07-14-2014, 02:00 PM   #2
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
lol at the 1/2" of toe out. I wish there was a non retarded option for camber plates. i cant use bolts... too much wheel/tire up front.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 07-14-2014, 02:33 PM   #3
wparsons
wparsons's Avatar
What wheels/tires are you running? I still have space up front with 17x8's and 225/45 ZII's even at -2* from bolts/slotted upper holes. I could probably run 15mm of spacer and not be poking as well.
flickr
Old 07-14-2014, 02:59 PM   #4
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Lol, my toe on rears was even worse OE
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
wparsons (07-14-2014)
Old 07-14-2014, 05:21 PM   #5
wparsons
wparsons's Avatar
Yeah, a good portion of the toe issues would have been present even at stock height and without the camber bolts. I had it done at CanAlignment and Scott said he has seen some cars off by A LOT right off the showroom floor.
I'm just pissed at myself that it took me so long to make time to get it done right!
flickr
Old 07-14-2014, 06:11 PM   #6
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
What offset? Mine are same size +48mm and I was really close with 225/45 MPSS. Just switched to 245/40 Conti DWs and the tire rubbed the perch. A 3mm spacer gave a teeny bit of room, then I switched to a 5mm and I'm much more comfortable with the gap.
I'm just over -1 degree with camber bolts in the bottom holes to maximize clearance at the perch.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 07-14-2014, 06:13 PM   #7
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Impressive alignment rig to be able to measure to .01 accuracy. What springs did you use and how much lower?
I took my car to sears for alignment. Gave them my specs and they matched it. (-2.0~-2.3f -1.5~-1.7r) I had 2 sets of camber bolts out front in my stock suspension and measured -2.3 on one side and 2.0 on the other myself before taking it in. The before adjustment specs sears got were -3.0L and -2.7R... That's stock suspension with just camber bolts. I think their machine is either mis calibrated or drunk. -3.0 is unheard of...
Old 07-14-2014, 08:46 PM   #8
wparsons
wparsons's Avatar
Mine are +45. I've got extended ARP studs so I can run more spacers, with 2* up front I want the wheels out a bit more so they aren't so sunken in.
Swift sport, about 1" drop.
His machine is definitely a good one, all the local racers go straight to him.
http://canalignment.com/
Anyone withing driving distance in Canada should definitely go see him for an alignment.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
2point0 (07-14-2014), solidONE (07-15-2014)
Old 07-15-2014, 11:13 PM   #9
solidONE
solidONE's Avatar
Almost the exact same setup I had at one point. RPF1 17x8 +45 with 5mm spacer at the front, Swift Sport BRZ, and 2 sets of Camber SPC bolts out front. Worked well for me.
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 05:41 PM
Alignment After Lowering mjsivee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-11-2013 11:12 AM
Big O For Alignment? djliquidsteele Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 02-19-2013 05:21 PM
Proper Alignment - Post Eibach Pro Lowering Thatruth2001 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-10-2012 01:48 AM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 02:57 PM
