Old 09-10-2012, 01:48 AM   #1
Thatruth2001
Drives: Raven FR-S
Proper Alignment - Post Eibach Pro Lowering
First and foremost, please help a 40 year old noob out.
After market parts is a whole new world to me. I have scoured through the forum for the past few hours and have an idea of what I need, but want to make sure. So if someone could help me out with the questions below it would be appreciated. Just as an FYI I had the car aligned after lowering the car, but the proper alignment (2013) information was not available in the shops computer.
Setup - 18" rims with 225/40 front and 255/35 rear Michelin Pilot Sport AS Plus Tires with Eibach Pro Kit.
Post Lowering - What is the proper alignment specs after lowering the car 1"?
Camber Adjustment Front / Rear - Can a proper alignment be accomplished in the front with the stock equipment to maximize tire wear?
Camber Adjustment Front / Rear - Based on the posts it sounds like, camber bushings will be required. If so, where can I find these items, any good particular vendors?
Thank you in advance for your assistance
Thatruth2001 is offline   Reply With Quote
Eibach Pro Kit Lowering Springs for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 1 09-25-2012 12:14 AM
alignment with Eibach springs? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-17-2012 11:34 AM
Eibach Pro Kit Lowering Springs for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 15 07-21-2012 11:46 PM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 02:57 PM
Anyone running Eibach lowering springs? Bahraini86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-01-2012 02:05 PM
