Drives: Scion FR-S
Alignment After Lowering
I just lowered my car about (-1.5 in all around), and I am trying to go in for alignment at a performance alignment shop and am not sure what kind of specs I should need.
RCE TARMACS 2'S 18 X 9.5 +40 57 Extreme Gramlights (all around) 235/40/18 Michelin Pilots Sport 3's From what I read on the forum I should go with -2 camber in front and -1 camber in rear with toes at all zero.. Do I just go into an alignment shop and ask for this...and they should be able to figure out the rest....Any help would be greatly appreciated.. |
Drives: '13 DGM BRZ Limited
Do you have anything to adjust the camber with, i.e. LCA's or Whiteline UCA bushings in the rear? The fronts should be adjustable a bit since they are slotted. If you don't have anything on the rear, you won't be able to adjust anything except toe.
I went with -2* front with 1/32" toe out and -2.3* rear with 1/16" toe in. Your setup may vary depending on what you plan on doing, i.e. DD, track, etc. You want the camber as even as possible right to left and I would suggest at least 1/16" toe in on the rear. Last edited by cnk; 08-15-2013 at 03:21 AM. |
| The Following User Says Thank You to cnk For This Useful Post: | mjsivee (07-22-2013) |
Custom User Title
Drives: Asphalt FR-S MT
@cnk
What do you use your car for?
| The Following User Says Thank You to boredom.is.me For This Useful Post: | Mr.Jay (08-11-2013) |
It's my DD, but I work from home so it's more of a pleasure/entertainment car for me. I had my alignment guy give me a more aggressive setup based on my driving preferences.
Sent from my Transformer using Tapatalk 4 |
| The Following User Says Thank You to cnk For This Useful Post: | boredom.is.me (08-11-2013) |
Call us if you need help!
- Andy |
| DIY Alignment | FRSFirestorm | DIY (Do-It-Yourself) Guides | 41 | 01-31-2020 07:06 PM |
| Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More | SOURCE,LLC | Brakes, Suspension, Chassis | 445 | 05-11-2015 05:41 PM |
| DIY Alignment | FRSFirestorm | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 10-03-2013 05:29 PM |
| Proper Alignment - Post Eibach Pro Lowering | Thatruth2001 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-10-2012 01:48 AM |
| Alignment needed after lowering car? | Lowellrenzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 06-16-2012 02:57 PM |
