Drives: WRB BRZ, Monte Carlo SS
Alignment question?
I have a brz limited with tarmac 2 coilovers and raceseng camber plates with a aftermarket rear control arm.
Tires are bridgestone re-11 255-35-18 I'm looking for a street/ track ready car. Any alignment suggestions. @CSG Mike |
Default spring rates?
-3.3 camber 6.8 caster 0 toe front -2.7 camber 1/16" total toe out rear. This is a track alignment specific to the RCE T2, for experienced drivers. Reduce camber in the rear slightly if you feel the car is too loose on corner exit |
I was looking for a hybrid setup that would work well on the streets and on a hpde event. 400 spring rates
#4 | |
driving smoother faster
Drives: Sold
Alignment question?
I use -3.4f -2.7r with Ohlins R&T per Mike's recommendation on Michelin PSS 225/45R17 and 7.5in rims on street and Toyo Proxes RA1 235/40R17 and 8in rims on track, with extra 2deg caster in front and no toe, somewhat lowered, and love the setup on street and especially on track. Track photo of my car in a fast turn shows wheels have good angle under compression (could have gone 10mph+ faster). I do experience some push on grooved highways and a little bit of wiggle on power in straight line with JR SC but this is a fantastic set up for me on track. Not the same setup as yours but FYI. |
#5 | |
Zero out the toe in the rear for street use, or 1/16" total toe in front AND rear for stability. it'll hurt cornering at the track. Do you want street stability or on-track grip? |
Drives: 2013 BRZ Limited
What camber settings do you recommend for RCE Yellows?
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
Yes, HVT camber plates, SPC camber bolts, and rear LCAs. I did not want coilovers since the car is a DD, but I wanted to be able to have a legit track alignment. So yes... my alignment is fully adjustable.
#9 | |
Start at -3 in the front and rear. Get some pyrometer temps, and get back to me. It'll be much more willing to rotate than stock, but may feel "loose" to you due to the huge weight transfers from the increased grip. |
#10 |
Thanks for the props! I'm doing a PCA HPDE day on June 7th at Miller Motorsports Park. I'll let you know how it does.
#11 | |
Also, should I buy some lightweight 17x8s (that was my initial plan), 17x9s, or just throw the tires on the OEM wheels? I have another set of wheels that I use for DD so these will be strictly for my track tires. Edit: This is a NA build. ~200whp
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com Last edited by zdr93523; 05-12-2014 at 12:53 AM. |
#12 |
@CSG Mike I'm running Eibach sway bars too. Will it be too loose at -3 degrees camber in the rear with the bars. I'm going to start with them both set to soft.
Sent from my LG-D800 using Tapatalk
#13 | |
Coopers are NOT comparable. The car will only feel overly loose if you're swinging the weight around. Smooth, controlled inputs are key. |
#14 | |
Thanks for all of the input. I'll get the alignment dialed in prior to the HPDE day. I'll probably burn up the stock Primacy's and then get a dedicated set of wheels and RS3s. I'll report back with tire temps once I get it out on the track.
| Tags |
| alignment, hpde |
| Alignment Question and issue | whitefrs | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 03-31-2014 07:42 AM |
| brz alignment question | Shenks | BRZ First-Gen (2012+) — General Topics | 2 | 02-12-2014 09:23 PM |
| Rear Camber/Alignment Question | anewprelusion | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 09-25-2013 11:39 PM |
| alignment question | hanabie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 08-15-2013 12:52 PM |
| Alignment question | retrosmiths | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-11-2013 10:44 PM |
