Drives: 2013 FRS asphalt
switchback install
okay well i bought my FRS a month ago and it already had switchback's installed, well one decided to stop working so i need to take them out and just put the stock bulbs back in, the question is how to i get the LED's out? do i have to take off the whole bumper?
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
1. Turn the wheel to the left or right depending on which side you're removing.
2. Remove the bottom three plastic screw retainers on fender liner. 3. Pull fender liner back. 4. Reach in and grab the bulb housing. 5. Twist to disconnect the bulb housing. 6. Remove bulb and replace. 7. Repeat steps in reverse. Should take about 10 minutes tops. |
| The Following User Says Thank You to dhuang For This Useful Post: | leoh007 (04-21-2015) |
Always Moving Forward
Drives: 2013 Argento Scion FR-S
If you haven't put the stock ones back yet, you should try just unplugging the LED for like a minute and then plug it back in and see if it works. Mine have stopped working a few different times, but when I unplug and then plug it back in, they start working again lol. Just a thought.
J.B. |
#6 | |
Drives: 2013 FRS
I few years back, I bought some cheapie LEDs from ebay, they would flicker after a while. I would have to push them back into the sockets and they would be good for a week or two. After that, I said screw it and put stock bulbs back in. |
| Switchback LED Question | rmbstyle | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 01-28-2015 03:01 PM |
| LED Switchback question. | AintTrying2Race | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 07-03-2013 03:33 PM |
| Need Help w/ Switchback LED! | bhbnuckle | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 04-30-2013 10:10 AM |
| switchback LED assistance | Gen | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 10-09-2012 10:41 PM |
| Switchback LED's | SocalBurt | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 09-03-2012 01:37 PM |
