Old 10-09-2012, 08:36 PM   #1
Gen
Drives: Scion FR-S
switchback LED assistance
I recently picked up some switchback LEDs to try out from DDM and I'm having a bit of trouble. There is a resistor wired into each. If I fire up the lights, the 'white' works perfectly fine. If the lights are off, the amber turn signal function works perfectly fine.
However, if I have the lights on (white) and use the passenger side blinker, the LED will flash amber once and turn completely off. Driver side, I can use the blinker normally for one attempt, however if I turn off the blinker and start it again, it will blink amber once and turn completely off. If I turn the lights off and back on it once again will work.
Any ideas?
Gen is offline   Reply With Quote
Old 10-09-2012, 09:36 PM   #2
paaji
paaji's Avatar
Drives: BA Falcon, GT86 on order
For LED indicators, you should use a replacement flasher relay that is suited to LED's. Not sure who supplies them in your country.
In OZ, Narva make them.
paaji is offline   Reply With Quote
Old 10-09-2012, 10:41 PM   #3
Gen
Drives: Scion FR-S
After a bit of research, it appears to be a common problem with their bulbs. Looks like I'll send them back.
Scion Roadside Assistance Telephone Number russv Scion FR-S / Toyota 86 GT86 General Forum 6 02-21-2013 10:08 PM
Switchback LED's SocalBurt Cosmetic Modification (Interior/Exterior/Lighting) 7 09-03-2012 01:37 PM
