Drives: White like Chocolate
Traction and CEL Light
Today I had my traction control light come on once again. This is the 3rd time. I took it to the dealer both times. First time they changed out the ECU and it fixed it for a little then the lights came back. Then next the problem was the camshafts or cam sprocket (can't remember off the top of my head). But now its back. Anyone aware with what the problem can be. I have a manual Transmission
#2 | |
Drives: Black 86
Had lots of 86/brzs here in the Philippines encountering that. Toyota dealers have been replacing the brake switch near the pedal.....fixed most of them. Good luck sir
Drives: 2013 FR-S, 2016 Miata Club
Has anyone disconnected the main engine harness in the past? That can throw out random codes if it's not seated properly when reconnected.
Junior
Drives: a car
I always thought AVCS failure was a different light, some weird CEL code.
Junior
Drives: a car
Whats your MY?
#10 |
#11 |
Junior
Drives: a car
Model year. Lol it took me a long time and some critical reading to figure it out haha
#12 | |
Cam actuator VVT issues usually CEL P0016,P0017,P0018,P0019. Usually triggers check engine light and car runs rough sometimes especially idle. Traction light usually indicates prblem with wheel speed sensors , brake switch or something weird with vehicle stability ABS systems ect. |
| The Following User Says Thank You to steve99 For This Useful Post: | cdrazic93 (04-08-2015) |
#13 |
#14 | |
| traction light, engine light = cam sprocket , ecu | nivek111070 | Issues | Warranty | Recalls / TSB | 27 | 03-13-2016 09:28 AM |
| Abs and Traction Light | nabil_frs | Issues | Warranty | Recalls / TSB | 14 | 07-09-2015 09:39 AM |
| ABS + Traction Light After Fog Install | Wyattkb | Issues | Warranty | Recalls / TSB | 1 | 03-22-2015 05:47 PM |
| CEL and Traction Light came on today | myjobis2pimp | NY / NJ / CT / PA | 9 | 10-05-2014 01:45 AM |
| CEL ABS and Traction Light | DieselxIndustry | Issues | Warranty | Recalls / TSB | 3 | 01-31-2013 01:04 PM |
