Old 03-22-2015, 05:21 PM   #1
Wyattkb
Drives: 2014 Whiteout FRS
ABS + Traction Light After Fog Install
So i just got done installing my fog lights into my FRS. After I got done, took it for a spin and the ABS + Traction control light came on after I exceeded 15 MPH. It goes off after I restart the car, but then comes back once I exceed 15 MPH again.
The only thing I can think of that may be causing this is somehow the wheel did not go back on straight (since I installed a new stalk). When driving straight the 12 o clock position of the wheel is at the 10 o clock position. Could this be causing the issue?
I am going to try and fix the steering wheel issue tonight. Just though I could pick some knowledgeable forum members brains in the mean time.
Thanks
Wyattkb is offline   Reply With Quote
Old 03-22-2015, 05:47 PM   #2
Wyattkb
So I figured it out.
What I did was drive down a dead end street and let the wheel find dead center by itself, stopped took wheel off then put it back on straight. No more issues.
traction light, engine light = cam sprocket , ecu nivek111070 Issues | Warranty | Recalls / TSB 27 03-13-2016 09:28 AM
Abs and Traction Light nabil_frs Issues | Warranty | Recalls / TSB 14 07-09-2015 09:39 AM
CEL and Traction Light came on today myjobis2pimp NY / NJ / CT / PA 9 10-05-2014 01:45 AM
Traction controll problem after steeing wheel install... NickGTI32 Issues | Warranty | Recalls / TSB 9 10-01-2014 03:09 PM
CEL ABS and Traction Light DieselxIndustry Issues | Warranty | Recalls / TSB 3 01-31-2013 01:04 PM
