Old 01-27-2013, 03:59 PM   #1
DieselxIndustry
Drives: 2013 Firestorm FR-S
CEL ABS and Traction Light
Auto FR-S
8100 Miles
This morning when I started the car it started fairly normal but as soon as I put it into gear i noticed the lights where on and as I attempted to drive It but it was clear that the car was having issues. Its so hard to accelerate, the speed literally increases 1 mph per second until I get up to around 15mph and then it maybe doubles. It feels as if I am driving in a higher gear from start. At 55mph the car is at around 4000 RPMs and even with the paddles doesn't want to shift into the next gear. I tried resetting the ECU but the lights came back on. I don't have a scanner to run the code for the light.
I have already had the ECU replaced and the fuel pump replaced per TSB. This seems similar to the limp mode issue but in my opinion it drives worse than it did before when I had the limp mode problems. I cant get anyone from Scion or the dealership because its Sunday. This is starting to get pretty aggravating with all the fixes needing to be applied.
DieselxIndustry is offline   Reply With Quote
Old 01-29-2013, 08:46 PM   #2
DieselxIndustry
Turns out some animal chewed into part of the harness for the transmission between the strut tower and the firewall. FML, car is 4 month old and this BS happened. BTW it happened on the night of a ice storm over the course of maybe 10-12 hours. To make things worse, Toyota wants $3100 to fix it.....
Old 01-31-2013, 12:27 PM   #3
speedracer38
speedracer38's Avatar
Drives: 2015 CWP Subaru BRZ Series.Blue
Was the car parked inside or outside? Your home owners / renters insurance should cover you.
speedracer38 is offline   Reply With Quote
Old 01-31-2013, 01:04 PM   #4
DieselxIndustry
Parked outside on the street, I have comprehensive coverage and rental coverage so I should be fine minus the 500$ deductible I have to pay :/ What really sucks is there is ZERO harnesses in the US right now so who knows how long this will take.
Issues - Traction control and ABS warning light on G86 Issues | Warranty | Recalls / TSB 109 10-17-2021 04:32 PM
Traction light flashing under trail braking; TC and VSC are both off... CSG Mike Tracking / Autocross / HPDE / Drifting 72 06-12-2016 08:18 AM
First Check Engine Light and Traction control QFry Issues | Warranty | Recalls / TSB 26 10-04-2014 11:27 PM
CEL Traction Control ON then OFF HATED1 Issues | Warranty | Recalls / TSB 5 09-24-2012 07:11 PM
CEL, Loss of Traction Light, Loss of Power pituala Issues | Warranty | Recalls / TSB 19 09-05-2012 11:23 AM
