Old 11-17-2013, 12:07 AM   #1
nabil_frs
nabil_frs's Avatar
Drives: Argento FR-S
Abs and Traction Light
Hey guys so this is the third time this has happened to me, cruising down the road and my abs and traction lights come on, not pushing the car or doing anything crazy just randomly comes on I havent checked if the abs or traction is still working(i.e launching or hitting the breaks) but after they come on I turn the car off and they go away, I'll probably take it to the dealer this week but has anyone else experienced this? The car hasn't been in any accidents or any incidents with curbs approx 45 000km on her
nabil_frs is offline   Reply With Quote
Old 11-17-2013, 01:25 AM   #2
humfrz
You could try disconnecting the battery to see if the ECU will re-set it.
However, it would be best to have a dealer look at it ..... it may be a bad sensor.
humfrz
Old 03-23-2014, 05:23 AM   #3
mnsayer
mnsayer's Avatar
Drives: LexusGS,Lotus Exige S240,LexusLX570
Did you solve your problem? what was the cause of it?
mnsayer is offline   Reply With Quote
Old 04-19-2014, 10:56 PM   #4
hamzam
Proud dad of 2 boys :)
hamzam's Avatar
Drives: Firestorm 6-MT
This recently has started happening to my car as well... has anyone had any luck?
hamzam is offline   Reply With Quote
Old 07-01-2014, 11:53 AM   #5
endless_pain
Pissin off regressives
endless_pain's Avatar
Drives: They have engines.
Did anybody mess with the clock spring? That can cause it.
endless_pain is offline   Reply With Quote
Old 07-02-2014, 10:56 AM   #6
Beebe
Beebe's Avatar
Drives: Totalled 2/7/15 :'(
Anyone know the cause?
These lights came on for the first time this morning for my BRZ too. I'm at 25K miles.
Beebe is offline   Reply With Quote
Old 07-02-2014, 03:43 PM   #7
Dezoris
Dezoris's Avatar
Pull the code and post back. Usually its a wheel speed sensor or brake pedal sensor adjustment issue.
Old 09-02-2014, 11:24 AM   #8
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
Subscribed
Attn: @KingGeo for info...
Cusco Suspension Braces | Eibach F & R sway bars | aFe/Takeda Intake | GReddy EVO3 | D2 RS Sport Coil-overs | TSW Interlagos | Centric Front Discs | Hawk HP+ (F) / HPS (R) | Goodrich SS brake lines | TSW & OZ Racing wheels | Continental & Hankook tires | JDP CF Front Lip | Rexspeed CF ground-effects kit | APR CF parts | Winjet headlights & fog lights | Valenti Smoked Reverse | TOM's LED taillights | CF interior upgrades | LED upgrades | and much more
FRS_Ken is offline   Reply With Quote
Old 09-02-2014, 01:14 PM   #9
extrashaky
Drives: 2014 BRZ Limited
I had this happen at about 17K miles in heavy rain. I scanned for codes, but Torque showed nothing. Shutting the car off and restarting cleared it. I'm up over 21K now, and it has never come back, so I choose not to worry about it.
I think it has to do with a wheel sensor either failing or getting dirty.
Old 09-02-2014, 04:01 PM   #10
moK
Drives: White BRZ
I had this problem, the lights would turn on randomly and reset when the car turned off. Turns out my brake light switch near the brake pedal was shorted. From the responses I've found here, the 2 lights could come on for numerous problems, not just what I had.
Edit: I should add that while it was all toasted inside (I opened it up), it still worked well enough for the brake lights to function.
moK is offline   Reply With Quote
Old 09-03-2014, 10:22 AM   #11
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
So - stupid reason for my problem - brake fuse.
They didn't cover it since i have mega-mods on the tails (i.e. Tom's LED tails and the Valenti LED Reverse/Brake light combo hooked in too).
They just charged me for 30-min. and a fuse = $65 CAD - I didn't argue.
Just a warning to people using a/m tails or LED bulbs in them - keep fuses handy!
I must have been driving around without brake lights too then - no wonder they lock you into Park on an auto - they don't want you driving around without brake lights either!
I wonder what, if anything, a blown brake fuse does on a manual? Someone remove thier brake fuse and report back?
Old 02-18-2015, 12:40 PM   #12
Kwisak
Kwisak's Avatar
Drives: 2013 BRZ GBS
Just left the dealer about this problem I had the lights on but no codes that I could see with my obdII. They said it was a breaking switch that has gone out. Put a new one and so far no problems. They covered it under warranty at 36k with no cost to me. Hope it helps
Kwisak is offline   Reply With Quote
Old 02-18-2015, 01:07 PM   #13
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Any part numbers or other invoice details?
It would be nice to go back to my dealer with info. It was just convenient for them to blame my Toms tails and Valenti reverse lights for the blown fuse.
Thanks
Old 03-04-2015, 03:38 PM   #14
Kwisak
Kwisak's Avatar
Thanks
Sorry for the delay, I have been out of town for fathers surgery. What I got was a 83311FG000 Switch Stop Lamp
What was written was 31714 Verified last visit that ABS light off code stored codes C1249 brake light switch malfunction. inspection erratic operation test and replaced brake light switch. Adjusted switch and adjustment is good. Light working
Basically they said the switch under the pedal was malfunctioning and they had to place in a 83311FG000 Switch Stop Lamp. But my symptoms were the same as the original poster with the ABS and traction control lights coming on constantly. They covered under warranty and knew exactly what is was when I showed the them what was happening so I assume I am not the first to come in with it.
Edit: Additionally the car has been driven while I was gone by my wife and the lights have not come back so its been almost a month with no problems so I think they got it
Traction Control Light Constantly On Cal3000 Issues | Warranty | Recalls / TSB 26 12-25-2016 05:20 PM
CEL and Traction Light came on today myjobis2pimp NY / NJ / CT / PA 9 10-05-2014 01:45 AM
lowered car and traction control light came on Shipwreck Issues | Warranty | Recalls / TSB 2 11-05-2013 05:18 AM
hit a curb HARD, traction control and ABS light on now need help plz! EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 02-28-2013 04:08 PM
CEL ABS and Traction Light DieselxIndustry Issues | Warranty | Recalls / TSB 3 01-31-2013 01:04 PM
