Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 05-10-2013, 06:27 PM   #1
myjobis2pimp
myjobis2pimp's Avatar
Drives: Raven Kraftwerks Supercharged FRS
CEL and Traction Light came on today
Just driving and both of these lights came on and the traction light went off then came back. The check engine light never went off. Called dealership so that I can bring it in but has anybody had this problem and if so what was the issue.
myjobis2pimp is offline   Reply With Quote
Old 05-11-2013, 11:13 AM   #2
mike123mdc
Drives: Subaru Brz
same thing happened to me. ended up just being the gas cap wasnt on tight
mike123mdc is offline   Reply With Quote
Old 05-11-2013, 11:23 AM   #3
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
the gas cap would throw a CEL but the slip light?
dori. is offline   Reply With Quote
Old 05-11-2013, 02:15 PM   #4
mike123mdc
Drives: Subaru Brz
ya slip light came on too. it was weird
Old 05-11-2013, 07:30 PM   #5
myjobis2pimp
That's crazy that it would cause the slip light to come on as well. I thought it might have been the gas cap as well. I opened it up and closed it back tight but lights are still on. So I'm gonna run it on my Toyota Techstream and see if the problem comes up. If not then I'm gonna take it into Toyota this week because I don't want to chance it if it happens to be something else. I just hope it isn't something major because I just got the car in March. But thanks for responding @mike123mdc
Old 05-11-2013, 07:36 PM   #6
reflex2o3
reflex2o3's Avatar
Drives: firestorm frs, manual
they might have to update ur computer if they havent yet
reflex2o3 is offline   Reply With Quote
Old 05-11-2013, 09:22 PM   #7
tvpr
tvpr's Avatar
Drives: 2013 Asphalt FR-S 6MT
My FR-S did the same thing about a month after I bought it. Had to take it in and get the ECU replaced. There's a whole thread on the issue here:
http://www.ft86club.com/forums/showthread.php?t=15577
tvpr is offline   Reply With Quote
Old 05-16-2013, 10:49 AM   #8
jmelgar23
Drives: 2013 SWP BRZ Limited
Same thing happened to me a while ago, had to to get the ECU updated. Hopefully everything works out man!
jmelgar23 is offline   Reply With Quote
Old 10-04-2014, 11:54 PM   #9
Astroboy
Astroboy's Avatar
Drives: None
What was the problem?
Astroboy is offline   Reply With Quote
Old 10-05-2014, 01:45 AM   #10
veck
veck's Avatar
Drives: 2014 Subaru BRZ
I had this problem and checked the fault code on torque app. Mine was due to system too rich error. If you have aftermarket air intake then that might be it.
veck is offline   Reply With Quote
Issues - Traction control and ABS warning light on G86 Issues | Warranty | Recalls / TSB 109 10-17-2021 04:32 PM
Traction light flashing under trail braking; TC and VSC are both off... CSG Mike Tracking / Autocross / HPDE / Drifting 72 06-12-2016 08:18 AM
First Check Engine Light and Traction control QFry Issues | Warranty | Recalls / TSB 26 10-04-2014 11:27 PM
hit a curb HARD, traction control and ABS light on now need help plz! EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 02-28-2013 04:08 PM
CEL ABS and Traction Light DieselxIndustry Issues | Warranty | Recalls / TSB 3 01-31-2013 01:04 PM
