Old 04-05-2015, 10:16 PM   #1
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
What the hell came out of my trans/diff?
Changed out my trans and diff fluids this past weekend. Used the same pan straight from one to the other so I'm not sure if these little buggers came from the trans or diff. I should have known to drain and inspect each fluid separately.
What the hell are these?
Is my trans or diff going to explode in a fiery inferno from hell at the track next weekend?
Oh, and to clarify, the penny did not come out of the trans or diff. It's just there to reference size. Although, it would be nice if this car started giving me some money for a change.
BatStig is offline   Reply With Quote
The Following User Says Thank You to BatStig For This Useful Post:
Packofcrows (04-06-2015)
Old 04-05-2015, 11:10 PM   #2
stevesnj
stevesnj's Avatar
Thats a horseshoe clip. It's for something that rotates on a pin under tension, the washer is to keep it tight. I'd look at the trans linkage or clutch linkage.
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
BatStig (04-06-2015), Tcoat (04-06-2015)
Old 04-06-2015, 07:53 AM   #3
mrk1
Drives: Sterling BRZ Ltd
It's not from the diff, nothing that small in there.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Old 04-06-2015, 08:32 AM   #4
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
What he said. Not something normally used internally, and not something normally used for parts that aren't supposed to come apart at a later date.
The last time I used a clip like that was for brake shoes- on a car built in 1978. As noted, shift linkage is a good place to look.
celica73 is offline   Reply With Quote
The Following 3 Users Say Thank You to celica73 For This Useful Post:
BatStig (04-06-2015), stevesnj (04-06-2015), Tcoat (04-06-2015)
Old 04-06-2015, 12:14 PM   #5
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
None of the snap rings or washers look like that inside of the transmission. I think you just had something in your pan prior to the drain. It's possible they were in there but they aren't supposed to be.
Thanks,
Phil
Element Tuning is offline   Reply With Quote
The Following User Says Thank You to Element Tuning For This Useful Post:
Old 04-06-2015, 12:28 PM   #6
Pish
#teamswagoi
Pish's Avatar
Drives: 2014 Raven FR-S Monogram
For a minute there I actually thought that penny came out as well hahaha !
Pish is offline   Reply With Quote
The Following User Says Thank You to Pish For This Useful Post:
Old 04-06-2015, 12:40 PM   #7
BatStig
Some say.....
BatStig's Avatar
Thanks,
Phil
Thanks for the quick response! The pan was borrowed from a friend. I guess it's time to send the pic to him and give him shit for giving me a heart attack.
Tcoat (04-06-2015)
Old 04-06-2015, 12:42 PM   #8
BatStig
Some say.....
BatStig's Avatar
I'm sure you're not the only one. That's why I put the "clarification" in the OP. Good on you for admitting it!
Old 04-06-2015, 01:43 PM   #9
bee-jay
bee-jay's Avatar
Drives: 2014 BRZ LTD WR Blue Pearl
looks like a common parking brake lever attachment clip on rear brake shoes (drum). Bet he was doing rear shoes on something.
bee-jay is offline   Reply With Quote
The Following 2 Users Say Thank You to bee-jay For This Useful Post:
Old 04-06-2015, 02:08 PM   #10
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I almost thought the penny came out. Then i kept reading.
The Following User Says Thank You to cdrazic93 For This Useful Post:
Old 04-06-2015, 02:11 PM   #11
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
This is why a banana should be used for scale.
The Following 2 Users Say Thank You to Andrew025 For This Useful Post:
BatStig (04-06-2015), gramicci101 (04-06-2015)
Old 04-06-2015, 02:16 PM   #12
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
hahah I thought penny came out of it too!
Which reminds me. Back in 2009
Found a cat under my hood.... on my Celica.... poor cat somehow died in there and got mauled by the fan(s).
Didn't drive car for like a month, then had friend pressure wash engine and everything in there.
Packofcrows is offline   Reply With Quote
Old 04-06-2015, 02:28 PM   #13
BatStig
Some say.....
BatStig's Avatar
Thanks everyone!
And sorry for the penny. I will definitely use a banana next time. Although, $5 says someone would have thought the banana was in there.....
Tcoat (04-06-2015)
Old 04-06-2015, 02:35 PM   #14
Dude, wrong forum!
Help! Washers for Oil/Trans/Diff Bevans555 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 05-12-2023 09:41 AM
What oil to use in your Engine, Trans, Diff? ArKiTeCkT CANADA 31 03-10-2018 03:23 PM
Amsoil Trans/Diff Changeover Vukodlac Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 02-11-2016 09:36 AM
Where can I buy the trans and diff washers? ngabdala Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 05-09-2013 12:35 AM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 03:11 PM
