Old 05-08-2013, 01:02 PM   #1
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Where can I buy the trans and diff washers?
I was hoping someone could provide me with a link and/or part numbers so I can order the trans and rear diff washers.
If I buy from Subaru are they going to charge me too much?
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 05-08-2013, 02:15 PM   #2
yamsta
daGangsta
yamsta's Avatar
Drives: 2013 FR-S 6MT
Transmission Oil And Diff Oil Change DIY: http://www.ft86club.com/forums/showthread.php?t=19218
M/T Fill/Drain plug gasket: 17008AA050
Rear Diff Fill plug gasket: 11126JB000
Rear Diff Drain plug gasket: 1215710010
Try online Subaru dealer or your local Subaru dealer.
yamsta is offline   Reply With Quote
Old 05-08-2013, 04:31 PM   #3
Hanakuso
I found it cheaper to buy online in bulk. I have enough for about 10 changes. I ended up buying crush washers for the oil changes as well.
Hanakuso is offline   Reply With Quote
Old 05-08-2013, 11:54 PM   #4
kster1
kster1's Avatar
I'm new to the BRZ; where did you buy the parts online from? Thanks.
kster1 is offline   Reply With Quote
Old 05-09-2013, 12:35 AM   #5
Hanakuso
I bought it through subarugenuineparts.com but I know a few other places like subaruonlineparts.com. Just go with whats the cheapest
What oil to use in your Engine, Trans, Diff? ArKiTeCkT CANADA 31 03-10-2018 03:23 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Can the transmission crush washers be reused? brillo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 04-15-2013 07:35 PM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 03:11 PM
MT fill and drain washers diirk Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 11-09-2012 12:24 AM
