Old 10-11-2014, 06:44 PM   #1
Bevans555
Drives: 2013 scion frs
Help! Washers for Oil/Trans/Diff
My car has hit 30k mi and im planning to change my engine oil, trans fluid & diff fluid next weekend on my 6MT and am ordering the parts now. After searching the forums I found that the washers I need are:
(2) Trans Fill/Drain plug washer - SU00303626 -Dealer special ordered today
(1) Diff fill plug washer- SU00300122 - Dealer special ordered today
(1) Diff drain plug washer- TOY1215710010- In stock and bought today.
I left the dealership with a new oil filter and the diff drain plug washer (washer on right in pic). Later I realized that I didnt have a new washer for the engine oil drain plug so I went back and the parts guy told me that the gasket he gave me earlier was the drain washer. I tried to explain to him that what I bought earlier was the diff drain washer and i also needed a washer for the engine oil drain plug, so he gave me a blue/black colored washer(washer on left in pic). After searching through more threads on here I found a pic of an engine oil drain plug with a washer on it that looks just like what is suppose to be my diff drain washer... now im unsure of what washers i received today.
Does anyone have a pic of the engine oil drain washer as well as of the diff drain washer? Or could someone tell me if the washer he gave me for the engine oil drain plug is in fact right?
Sorry, I just want to make sure I have all the right parts.
Thanks
Bevans555 is offline   Reply With Quote
Old 10-11-2014, 07:22 PM   #2
roddy
roddy's Avatar
Drives: '13 Ultramarine
Both the engine and rear diff use the thin steel "crush" type washers. The I.D. (inside diameter) of the one for the engine is 16mm, and the ones for the diff are 18mm. This type of washer/gasket must be replaced each time. The transmission uses the thicker soft aluminum type, and they can be re-used in a pinch without leaking. The one you have pictured for the engine is not the "correct" one. If the I.D. is right, you may still be ok to use it. What is it made of?
Old 10-11-2014, 07:33 PM   #3
Bevans555
Thanks for the reply. The diff washer is 18mm and steel, so it is right. However, he gave me the wrong engine washer.. it is aluminum with a soft paint like coating on it and it only measures 12mm ID. Is there a part # for the engine oil washer?
Old 10-12-2014, 01:10 AM   #4
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
That washer on the left is the generic one used in all Toyota models. I have a bunch for my Toyota and if you need I can compare them to my brz washers if it would help you but I would not readily use that on my brz. The Toyota parts guy gave you that one because it's all he knows and is used to.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 10-12-2014, 08:51 AM   #5
Bevans555
Thanks Laika!
If its not too much of a hassle, could you snap a pic of the engine washer? Im going back to the dealer Monday and would like to show the parts guy a pic of the washer. Or would I be safe in saying the engine washer looks identical to the diff washer only with a slightly smaller inside diameter?
Old 10-12-2014, 11:32 AM   #6
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by Bevans555 View Post
Thanks Laika!
I compared both the Toyota generic washer and the Subaru crush washer. The outside diameter is about equal but the inside diameter is not.
Can you get away with using the toyota one? Probably. Could it even be better than the Subaru one? Maybe. I'm going to continue using the Toyota one in my Toyota and the Subaru one in the BRZ.
Old 10-12-2014, 11:36 AM   #7
roddy
roddy's Avatar
The one for the oil pan looks the same as the ones for the diff, but smaller. I believe the part number is SU003-02159, but have your parts guy check to be sure.
Old 10-12-2014, 12:18 PM   #8
Bevans555
Thanks guys!
Old 10-12-2014, 11:04 PM   #9
frslee
Just drive it
Drives: 13' FR-S
I use this as replacement gaskets. Since transmission washers are flat steel, I reuse those. I believe differential drain plug is crush type, so replaced with these.
http://www.pepboys.com/product/detai...nlyStore=false
frslee is offline   Reply With Quote
Old 10-13-2014, 01:47 AM   #10
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Don't reuse the engine oil drain plug. Get a Fumoto. Makes future oil changes a piece of cake.
And by the way, the diff fill and diff drain washers are identical.
Fizz is offline   Reply With Quote
Old 10-13-2014, 08:12 AM   #11
smellslikecurry
I've been using generic copper washers (oil pan) on my car for the last 37,000 miles without any issues.
smellslikecurry is offline   Reply With Quote
Old 05-12-2023, 06:12 AM   #12
r4mr4m3024
Drives: gt86
Hello friends, I had to change the differential oil and gearbox oil, but I realized that I need their washers. After a lot of research and searching, I realized that I cannot order the original samples. I want to use similar samples. What kind of washers can I use for my gearbox and differential? Thank you, it is very important, my car is on the jack waiting for your answer
r4mr4m3024 is offline   Reply With Quote
Old 05-12-2023, 07:08 AM   #13
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Subaru
1215710010 Diff Drain Gasket
11126JB000 Diff Fill Gasket
17008AA050 Transmission Gaskets
803916010 Oil Drain Gasket
Toyota
TOY1215710010 Diff Drain Gasket
SU00300122 Diff Fill Gasket
SU00303626 Transmission Gaskets
SU00302159 Oil Drain Gasket
Alternate : https://www.amazon.com/dp/B01FUVMDBC...op_mb_pd_title
Old 05-12-2023, 07:11 AM   #14
spcmafia
spcmafia's Avatar
@ichitaka05 Is there a way that we can make a sticky section for all crushers and washers, fluids for the twins? I'd be more than willing to do the research.
What oil to use in your Engine, Trans, Diff? ArKiTeCkT CANADA 31 03-10-2018 03:23 PM
Replacing Trans & Diff Fluid, Hot vs Cold BRZNutt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 12-22-2013 09:04 PM
Where to order trans/diff gaskets? ZionsWrath Scion FR-S / Toyota 86 GT86 General Forum 4 11-11-2013 01:46 PM
Where can I buy the trans and diff washers? ngabdala Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 05-09-2013 12:35 AM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 03:11 PM
