Old 02-21-2015, 05:31 PM   #1
mack4477
Drives: 2013 Firestorm FR-S
Best tire for traction on 18x9.5 +38?
Everyone looks for different things in a tire. I need grip. Tired of breaking loose when I hit boost in 2nd. Want to get it fixed before heading to TX2K next month for some spirited driving.
So, best tire for traction that can be daily driven? Not interested in the street drag radials.
And will 265/35 fit without rubbing on a car dropped on S Tech springs?
mack4477 is offline   Reply With Quote
Old 02-21-2015, 06:42 PM   #2
nelsmar
I am on NT05 265/35 with -1.9* camber in the rear (stock LCA/UCA, natural camber from drop) at I forget how low.... I have a very slight rub under suspension load. Its a tad tight of a fit. As for grip it isnt as much as I was hoping, I guess its time to try some NT05R instead for the next round. I still spin 3rd @ ~16PSI on E85 (although manageable), and anything higher is just worthless.
My flickr - Canibeat
Local magazine scout
Old 02-21-2015, 08:54 PM   #3
mack4477
I remember your name, but haven't been around the forums much over the last year. I forget how much power you're making. I'm at 400 whp. I always spin 2nd, and sometimes 3rd if the temp is below 50. My Direzza Z2s just don't do the trick. Sorry to hear about your issues, but as the NT05 was on my list of possible options I'm glad I heard his from you first. Seriously have no idea which way to go on this.
My 255 seem to have a little room to breathe under there. The 265 is only .4" wider, so I'm hoping there won't be an issue with my springs. Just don't know what kind of rubber to use
Old 02-21-2015, 09:56 PM   #4
wparsons
wparsons's Avatar
First thing I would do is zero out the camber in the rear. A flatter tire is a good start for rear traction.
I'm not sure if most good sticky street tires will do much good unless you're going to heat them up first. Any of the sticky street tires I've driven need at least a full lap before they're heated up and sticky.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
mack4477 (02-21-2015)
Old 02-21-2015, 09:56 PM   #5
nelsmar
Honestly I have no idea exactly what my car puts down I need to get around to tossing it on the dyno... based off of others I have tuned my car on higher boost is probably low 500's. But its rare that I use that map... Transmissions and axles like to break. lol
Old 02-21-2015, 10:58 PM   #6
mack4477
My car was done almost 2 years ago now. At the time, 400 was huge. I didn't want to go bigger for that same reason...shit breaks. I never launch the car. But I would love to be able to hook from a 30 roll. It's only happened a couple times for me, and it puckered my asshole each time. I hope I can come up with something to make that happen on a regular basis
Old 03-10-2015, 05:16 PM   #7
Black86
Black86's Avatar
Drives: 2013 Raven Black FR-S
I hear the nt05 is good and bad from a lot of people. To many mixed reviews for me..the tires you have are pretty good, also toyo t1r tires are good I hooked 400+whp in my mk3 supra from 1st gear onward easy with those. Maybe some others with boost can chime in?
-Raven Black 13 FR-S : The daily driver
-88 supra turbo : 2jz 66mm single on E85 in the process
Black86 is offline   Reply With Quote
Old 03-10-2015, 08:37 PM   #8
8R6
8R6's Avatar
Drives: FRS
how about RS3's? My friend used to track his 350z on those and loved them
8R6 is offline   Reply With Quote
Old 03-12-2015, 12:08 AM   #9
BirgeyT1
too soon jr
BirgeyT1's Avatar
Drives: 2014 Sterling Silver BRZ Limited
I'll second that on the T1R's for being good. do they still make them? lol
T1 Race Development
ID Injector Dynamics
BirgeyT1 is offline   Reply With Quote
Old 03-12-2015, 12:15 AM   #10
8R6
8R6's Avatar
Drives: FRS
according to toyos site, they dont offer the T1R in 17s or 18s :/
Old 03-13-2015, 12:54 PM   #11
Black86
Black86's Avatar
I'm not sure they still do or not! I know I had them about a year and a half ago in 18" size but with all the new tire lines coming out they may not be available. The t1r was a great tire!
Old 03-13-2015, 01:00 PM   #12
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I had the NT-05 back in the day, and the tire performance seemed decent, but didn't last worth jack since they arrive 50% worn out.
On my srt, I think I got about 10-12k out of them...they were bald when I got rid of them
After I got them installed my buddies gave me bs about how the tire place did burn outs on the tires before giving them to me haha.
They come with tread depth of 7/32 btw
Old 03-13-2015, 01:09 PM   #13
Black86
Black86's Avatar
I just found on eBay 255/35/18, 265/35/18, and 255/40/18 toyo t1r! They are like 230 a tire though ha.
Old 03-13-2015, 01:11 PM   #14
Black86
Black86's Avatar
Damn that's b.s. They gave you used tires lol?! Wtf
i have 18x9.5 wheels whats the best tire for traction Anthony7515 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-19-2014 06:36 PM
Widest tire to fit on an 18x9.5 Wheel?!!! ** ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 60 07-07-2014 04:08 PM
Best tire size for 18x9 et 35 TmP Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 47 05-25-2014 10:02 PM
18x9.5 +38 tire upgrade question ft86me Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-23-2013 01:22 PM
Tire shop wants to argue... 18x9.5 +38 with 255's Skurj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 02-09-2013 11:27 AM
