Old 06-22-2013, 08:24 PM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
18x9.5 +38 tire upgrade question
currently have 245 40 18. can I go much wider such as 275? or would 265 be better? any experience and input would be great.
currently have whiteline camber bolts up front and cusco arms in the rear for adjustment of the camber. i'm not looking to stretch and pull and will be at a functional lowered height with my kw v3s
thanks!
ft86me is offline   Reply With Quote
Old 06-22-2013, 09:17 PM   #2
empower-auto
Kouki-Monster
empower-auto's Avatar
you're already doing it wrong.
235/40, 245/35, 255/35 will work better.
now .. if you plan to race / track the car ..... that front wheel size is going to be drama. It's fine for the street but with a 235/40 on an 18x9.5 +38 front I rub brutally even with 2 degrees negative camber. it may work at stock height with stiffer suspension but not for a lowered car.
I'm gonna have to cut my fender liners out it seems
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 06-22-2013, 10:37 PM   #3
ft86me
ft86me's Avatar
Drives: 2013 FRS
that's odd because i don't rub at all and already have taken it to willow. i have no fitment issues right now. i just want to go much wider since i noticed that i have lots of room. i'm also lowered on kw v3
Old 06-22-2013, 10:47 PM   #4
empower-auto
Kouki-Monster
how hard are you driving er?
I auto-x'd hard and really effed things up
Rich Anderson
EMPOWER AUTO
Old 06-22-2013, 11:22 PM   #5
ft86me
ft86me's Avatar
Drives: 2013 FRS
pretty hard man. also had a pro driver take my car to the limit since i was doing a comparison for media purposes as well
Old 06-23-2013, 01:39 AM   #6
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
Sorry for jack thread,
So 18x9.5 +38 all around with 255/35/18 will fit?
Scalzo is offline   Reply With Quote
Old 06-23-2013, 02:14 AM   #7
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
275 is the optimal size for a 9.5" wheel. In terms of fitment because of offset you may run into problems.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
The Following User Says Thank You to Tansey86 For This Useful Post:
ft86me (06-23-2013)
Old 06-23-2013, 01:30 PM   #8
ft86me
ft86me's Avatar
Drives: 2013 FRS
maybe a step down to 265 would work with some camber.
Old 06-23-2013, 01:44 PM   #9
Tansey86
Tansey86's Avatar
It all depends on how low you go. At stock height a 275 will be fine, the lower you go the more you'll get natural camber and poke because of the +38. If you lower it 1.5 inches and run 2* ull be fine
ft86me (06-23-2013)
Old 06-23-2013, 02:06 PM   #10
ft86me
ft86me's Avatar
Drives: 2013 FRS
you're awesome help! i have the kw v3 right now and it's at the factory drop height it came preset with and i have no issues with my 18x9.5 (r) 18x8.5 (f) +38 245 40 18 all around no rubbing or anything. i think i'll go the route of 265 35 18 and get 9.5 up front.
Old 06-23-2013, 02:22 PM   #11
Tansey86
Tansey86's Avatar
http://www.ft86club.com/forums/showthread.php?t=19954 - Jives car is 18x9.5 +40 square with 265/35/18's all around, hes got it dialed in to run awesome and the car looks mint. I'd discuss it further with him as he has more experience with the setup. Best of luck!
ft86me (06-23-2013)
Widest tire to fit on an 18x9.5 Wheel?!!! ** ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 60 07-07-2014 05:08 PM
Pioneer radio upgrade question... Jester Electronics | Audio | NAV | Infotainment 8 07-23-2013 06:04 PM
Maintaining stock tire size what to upgrade to... tuckdaddy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-03-2013 12:28 PM
Tire shop wants to argue... 18x9.5 +38 with 255's Skurj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 02-09-2013 12:27 PM
Replace one blown OEM tire or upgrade to Super Sport? Yellow_Jacket Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-23-2013 10:33 PM
