Old 02-21-2015, 12:33 PM   #1
EdiVip
Drives: Mario
19x8,5J Clearance on front
Hello Guys!
I have a problem with inner clearance on my GT86. Rays Gramlights 57FXX 19x8,5J ET45 rims with 245/30 tire rub swaybar when full lock. Does anybody have this issue? Car is lower about 1" and camber is -1
Suspension:
Bilstein – B8
Eibach – Pro Kit
Perrin – Front Sway Bar 19mm
EdiVip is offline   Reply With Quote
Old 02-21-2015, 05:11 PM   #2
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
I think its your offset. Im running 19x8.5 et40. no issues. i believe thats the max. also I'm on 235/35/19
Liquid6 is offline   Reply With Quote
Old 02-22-2015, 12:43 AM   #3
Sweet48
Sweet48's Avatar
Drives: 2013 Subaru BRZ
I'm running 19x8.5 +42, it cleared everything except my brakes (I have BBK) so I added a 5mm slip on (+37 after spacer). 245/35R19 (i realize the tires are slightly oversized, i got them for free so I cant complain lol)
I am also on coils and dropped around 1.75"-2" with camber plates maxed, unsure of the exact degrees, I havent gotten an alignment yet :'(
I'd say throw a small slip on spacer on there if I were you, see how that works. They're super cheap too, around $20 for a pair.
Sweet48 is offline   Reply With Quote
Front wheel clearance. Nigelr32 Cosmetic Modification (Interior/Exterior/Lighting) 7 01-04-2015 06:52 AM
18x9.5 e45 - 255/35/18 Tires - Front Strut Clearance Kuri Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 12-12-2014 10:30 PM
Best tire size for 19x8.5 front and 19x9.5 rear? Frs32907 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 01-03-2014 11:17 PM
BRZ front clearance a2cpc BRZ First-Gen (2012+) — General Topics 14 01-23-2013 07:38 AM
Inner wheel clearance at the front spiller Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-27-2012 12:40 PM
