Old 12-12-2014, 04:48 PM   #1
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
18x9.5 e45 - 255/35/18 Tires - Front Strut Clearance
I've already tried searching on all the threads for this fitment for tires to confirm that they clear the front strut. Also used all the calculators.
I seen a lot of threads and information on 38-40 offset , not much about +45 and tires used.
Can anyone confirm that this will clear my coils? (Don't give me crap about offset, I've got these wheels for a good price)
Running FA V500 + Camber Bolts -1 Drop -2 Camber
Planning to run 18x9.5 e45 with BFG Sport Comp 2 - 255/35/18 or
will I have to step back to 245/35/18 or
Just run 8mm spacers?
Kuri is offline   Reply With Quote
Old 12-12-2014, 05:46 PM   #2
8R6
8R6's Avatar
Drives: FRS
itll fit with 245 tires. not sure about 255 though...
8R6 is offline   Reply With Quote
Old 12-12-2014, 06:14 PM   #3
swarb
It should fit. All the problems everyone else has is from stock struts. Just get some 3-5mm spacers from a local auto parts store and keep them handy when installing the wheels. If they fit, return them or use them in the rear.
It won't rub the struts, but other things may rub. 3-5mm max spacers on stock studs.
Old 12-12-2014, 06:25 PM   #4
Yamaha_R6
Yamaha_R6's Avatar
Drives: V8 280Z || AP2 S2K
Here is the clearance for 18x9.5, et38 wrapped in 235/40 tires: http://www.ft86club.com/forums/showp...6&postcount=15.
Yamaha_R6 is offline   Reply With Quote
Old 12-12-2014, 10:30 PM   #5
Kuri
Kuri's Avatar
Thanks Yamaha. Swarb, I'll be on ARP studs tomorrow so thread count won't be an issue (pre planned)
Just hoping to see if anyone else has the same wheel / fitment.
#TrackDayBro
SOLD Work VS-XX 18x9"+34/18x9.5"+39 Toyo T1 Sport 245/255 tires SOLD mav1178 Wheels and Tires 11 10-20-2014 12:13 AM
Xxr 530 18x9.75 w/ tires Hmongfrs Wheels and Tires 20 12-19-2013 01:07 AM
WTB: 18x9.5/ 18x9/ 17x9/ 17x9.5 Square With or without tires loogs Wheels and Tires 11 12-08-2013 03:40 PM
225/40/18 Tires on 18x9.5 illmattic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 08-29-2013 09:13 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 01:52 AM
