Old 01-01-2014, 08:23 PM   #1
Frs32907
Drives: Asphalt grey, manual Fr-S
Best tire size for 19x8.5 front and 19x9.5 rear?
My rears are wearing alittle to fast i was windering if anyone could suggest a better tire size with stock suspension?
Thanks
Frs32907 is offline   Reply With Quote
Old 01-01-2014, 08:42 PM   #2
Joakim3
Joakim3's Avatar
Drives: 04' Saab 9-5 Aero
You normally would but 235/35 in the fronts and 255/35 or 30's in the rear but you could easily run 225/35 for the fronts and 245/35 rear, and depending on tire brand, barely look stretched all while helping out when it comes to not rubbing bearings and fenders
Joakim3 is offline   Reply With Quote
Old 01-01-2014, 10:06 PM   #3
s2d4
s2d4's Avatar
Are you sure you want to do that on 19s.... Or are you telling him to go with 18s?
Old 01-01-2014, 10:10 PM   #4
Joakim3
Joakim3's Avatar
If he were to stick with 19's then yeah those size would be closest to OEM without being rubber bands
If he wants to do 18's closest to OEM with that same wheel widths he would have to do 225-35/40 in the fronts and 245-255/40's in the rears
Old 01-03-2014, 11:17 PM   #5
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
I don't have 19's but I'm running Front: 235/40/18 Rear: 255/35 r
V12 rubber
After having it, I dont recommend staggering your setup, unless you are putting out some major power to the rear wheels, and you are seeking the widest rear tire possible.
Even with 235's to 255 the awesome balanced feeling is significantly lessened. If I keep my staggered setup, Ill be running a 245 on the front next time. Probably be FI by then.
I have no idea how some people are running the 225's in front with 255 rears :/
OjiGeorge is offline   Reply With Quote
Wheel Directory: Forgestar F14 19x8.5 +35 / 19x9.5 +38 exequtor1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 04-06-2015 08:59 PM
Wheel Directory: Five:AD R5:F 19x8.5 +45 / 19x9.5 +35 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 08-21-2014 11:09 PM
WTB: 1 OEM Size Tire for Rear taimysho0 Wheels and Tires 0 05-17-2013 03:34 PM
five axis r5-f 19x9.5 and 19x8.5 set fluffy-reindeer-slayer Wheels and Tires 18 04-15-2013 12:18 PM
Wheel Directory: HRE 540 19x8.5 +?? / 19x9.5 +?? howiedoit Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 01-15-2013 01:56 AM
