Old 06-27-2012, 04:51 AM   #1
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
Inner wheel clearance at the front
Im looking at some aftermarket wheels and have heard there isnt a whole lot of clearance between the inside of the factory wheel and the strut at the front. Does anyone know specifically how much room there is?
Specifically I am looking at a 9.5 +38 on the front and want to know if this will fit. I will be using aftermarket coilovers which usually have a much smaller spring diameter than factory arrangements.
Any reference points would be helpful.
thanks!
spiller is offline   Reply With Quote
Old 06-27-2012, 05:55 AM   #2
old greg
Rocket Surgeon
Drives: PSM GGA OMG
http://www.ft86club.com/forums/showthread.php?t=6964
It depends on what size tires you run, but 9.5 +38 with no stretch or pinch would be just about touching the spring perch of the stock dampers. With aftermarket coilovers you'd be fine.
old greg is offline   Reply With Quote
Old 06-27-2012, 08:13 AM   #3
spiller
@old greg thanks for that link, very helpful! So according to the info in that thread (Sti wheel being 7.5 +53) the 9.5 +38 will have 10mm less clearance on the inside so will definitely foul on the stock spring perch. you would think this will be fine with the much smaller diameter of aftermarket coilover springs wouldnt you?
thanks again.
Old 06-27-2012, 09:37 AM   #4
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
When I mounted 17x9 +42 with 245/40 Star Specs, their was about 1/8-1/4 of an inch of space between the tire and the spring perch. That is with nothing done as far as an alignment.
So that .5 inches on a +38 offset is only going to move it 3mm towards the strut housing. I think it would be fine but i'm no scientist.
Ranatsu is offline   Reply With Quote
Old 06-27-2012, 11:22 AM   #5
spiller
yeah i think with the stock struts it probably wont clear but I do need coilovers to make the wheels sit properly anyway which will give me some additional clearance. I'm unsure as to whether the tire will rub on the plastic liner when I turn full lock though. @Ranatsu do your tires rub on the plastic at all at full lock?
Old 06-27-2012, 12:40 PM   #6
Ranatsu
Cone basher
They didn't, but I only had them on for about 10 minutes test fitting them. I drove around in a cul da sac at full lock and it didn't rub.
STI front lip available taosracer Cosmetic Modification (Interior/Exterior/Lighting) 22 03-05-2013 10:06 PM
FR-S FRONT SEATS TRD86 Scion FR-S / Toyota 86 GT86 General Forum 28 10-09-2012 08:03 AM
no front LED strip? Lydin Scion FR-S / Toyota 86 GT86 General Forum 3 06-03-2012 02:05 AM
Clearance issues? eriktherod Scion FR-S / Toyota 86 GT86 General Forum 3 05-31-2012 03:50 PM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
