Old 02-19-2015, 01:34 PM   #1
rhythmM
rhythmM's Avatar
Drives: 2014 Subaru BRZ Limited MT - White
Can I run 235 square tires on my staggered wheels?
Hi guys,
I originally wanted to stay with a 17in squared wheel setup with a 1in drop, but found a deal that was too good to say no to on an 18in staggered setup.
They are 18x8.5 et43 and 18x9.5 et35. I'm still very interested in staying with a squared tire setup if possible, and was wondering if that was possible or not. I figured it was only a full 1in difference in width, and if the tires were to meet in the middle it'd be like a 1/2 inch difference. Then with the install and mounting, it would visually be like a 1/4 inch difference.
So with that said, if this is possible what size tires would you guys recommend for visual aesthetics? I was considering a size of 235/40/18 all around, but what do you guys think? Pretty new at this, so if you guys can give me your input and advice that would be great!
Phantom Super Charged - 2014 BRZ
rhythmM is offline   Reply With Quote
Old 02-19-2015, 01:57 PM   #2
jvincent
jvincent's Avatar
235 might look pretty stretched on a 9.5.
235 or 245 will be perfect on an 8.5 rim, so you'll have one set of tires stretched and one not. Depending on how bad the stretch is it might not be the best visually.
Old 02-19-2015, 02:14 PM   #3
rhythmM
rhythmM's Avatar
Yea I know that 235 on the rear would be somewhat of a stretch, but figured it wouldn't be too bad. Would you recommend doing 245 all around instead?
Old 02-19-2015, 03:05 PM   #4
jvincent
jvincent's Avatar
I'd check the recommendation for the tire, but 245 would probably be better.
Old 02-19-2015, 03:08 PM   #5
I would not recommend a 235 on a 9.5" wheel. 245 minimum, 285 maximum.
Old 02-19-2015, 03:20 PM   #6
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
I know 225s are relatively stretched on 8.75" wheels, so I bet 235s on a 9.5" wheel would be pushing it...
Also, 235s are a weird size and it might be easier/cheaper to find 245s.
FReSh is offline   Reply With Quote
Old 02-19-2015, 05:02 PM   #7
rhythmM
rhythmM's Avatar
Hmm, sounds like 245 is the way to go if I want to do a square setup huh? In that case, what profile would you guys recommend? Just sticking with 40% or should I drop it down to 35%.
35% kind of brings it down to the stock overall diameter.
Old 02-19-2015, 07:05 PM   #8
FReSh
Dirt Trackin'
FReSh's Avatar
Staying close to stock is probably best. The 245-35-18s are closest. The 40s will be a bit tall.
Square Tires on Staggered Setup OjiGeorge Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-10-2014 09:31 AM
Square tires on staggered wheels? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 11-28-2013 08:34 PM
Ok to have non staggered wheels but staggered tires? taimysho0 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-21-2013 11:57 PM
Staggered wheels + square tyre setup? white_knight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 03-18-2013 09:27 AM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
