Old 05-21-2013, 07:34 PM   #1
taimysho0
Drives: frs
Ok to have non staggered wheels but staggered tires?
Hi, im not planning to buy aftermarket coils, so wanted to keep my car stock. if i have same size wheels in front and in rear, but go wider tires in the rear, will that be ok? im thinking 225/45/18 in front and 245/40/18 in rear on same size rims all around
taimysho0 is offline   Reply With Quote
Old 05-21-2013, 08:31 PM   #2
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Yes--no issues.
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 05-21-2013, 10:03 PM   #3
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Its ok, but your tire choice has a larger diameter than the OEM spec, My suggestion would be Front 225/40/18, Rear 245/35/18.
adprokid is offline   Reply With Quote
Old 05-21-2013, 10:58 PM   #4
Flow
Drives: DGMBRZ
I see this comment a fair bit, and am wondering what are the real downsides to a larger than stock diameter, other than the speedometer being off...? Tks.
Flow is offline   Reply With Quote
Old 05-21-2013, 11:57 PM   #5
jshadeck
jshadeck's Avatar
Drives: 2013 Scion FR-S Whiteout 6MT
Taller gearing (ie slower acceleration / higher mph in each gear)
Possibly more mpg
Could be a rubbing issue
jshadeck is offline   Reply With Quote
what affect will staggered overall diameter wheels have? jshadeck Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 04-03-2013 06:57 PM
Wheel Directory: WedsSport TC105N 17x8.0 +42 / 17x9.0 +35 hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 56 03-08-2013 12:10 PM
why staggered wheels? koyv90 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 02-28-2013 06:02 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
staggered and unstaggered wheels 86 FRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-06-2012 04:27 PM
