Old 03-16-2013, 08:47 PM   #1
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Staggered wheels + square tyre setup?
Hey Guys,
I currently have a set of Continental ExtremeContact DW tyres (235/40/18) for my 18x8.75 wheels.
I want to sell the wheels and get a set of 57 Xtremes in staggered (18x8.5/9.5) and want to know if my tyres will fit them OK?
white_knight is offline   Reply With Quote
Old 03-17-2013, 08:10 AM   #2
infinite012
Drives: 13 DGM BRZ Ltd
235/40/18 would be a great fit on the 8.5. It would be a slight stretch on the 9.5.
infinite012 is offline   Reply With Quote
Old 03-17-2013, 09:08 AM   #3
white_knight
But there won't be any issues with handling or anything?
Old 03-17-2013, 10:10 AM   #4
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
I run a 255/35/18 on a 9.5 and its slightly stretched. Your 235s will be good up front but no good in the rear. The good news is that you only have to buy two tires and you have spares for the fronts...
chadstyle is offline   Reply With Quote
Old 03-17-2013, 10:32 AM   #5
infinite012
If 255/35 is stretched on a 9.5" wide wheel, either a) we have different definitions of the term "stretched" or b) I've become a hellaflushist (aka wrong)
Old 03-18-2013, 07:15 AM   #6
chadstyle
chadstyle's Avatar
I said "slightly stretched" which it absolutely is. Stretched=when the sidewall isn't square. Could you stretch a 235 or 245 on a 9.5"? Yes of course..would it look ridiculous? Yes, of course.
Old 03-18-2013, 07:40 AM   #7
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
What are your offsets of the wheels ? I run 18x8.5s +38 front and 18x9.5+38 rear with a 235/40 front and 265/35 rear on stock height and there's absolutely no issues with rubbing or clearance ... Just a slight poke in the rear but I like the look of it check out my Forgestar F14 thread in the wheels and tires forum
Many people told me they wouldn't fit whatsoever but I proved all them wrong
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 03-18-2013, 07:43 AM   #8
white_knight
Offset is 33 all round.
Old 03-18-2013, 08:45 AM   #9
ScionFR-S
ScionFR-S's Avatar
that may be a little too low of an offset, check the fitment calculator as well and also see who else is running a similar offset, if it was a little higher of an offset i would say it would def fit
Old 03-18-2013, 08:47 AM   #10
ScionFR-S
ScionFR-S's Avatar
http://www.ft86club.com/forums/showthread.php?t=30299
PM Him and see what he thinks
Old 03-18-2013, 09:27 AM   #11
white_knight
Sorry, did you mean offset of the 57 Xtremes? 40 in the front, 33 in the rear.
Staggered or Square? tdoggy57 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 09-26-2014 07:55 AM
Wheel Directory: WedsSport TC105N 17x8.0 +42 / 17x9.0 +35 hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 56 03-08-2013 12:10 PM
Staggered vs. Square WWEVOX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 01-12-2013 03:57 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Square or Staggered? dabocx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 02-02-2012 09:40 PM
