Old 02-14-2015, 04:10 AM   #1
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
What brake fluid do you use when bleeding/flushing the clutch?
I want to flush my clutch fluid but I have never done it before. For those who have, what brake fluid did you choose and why? Also, how much fluid do I need?
The service manual only lists the following:
Brake fluid and clutch fluid: FMVSS No. 116 DOT3, or DOT4
I know I could go to any auto store and pick up any bottle of DOT3 or 4 brake fluid, but I was wondering if any of the track guys here have a particular fluid that they prefer. I'm not saying that I want to put something in as expensive as Torque 700, but maybe Motul RBF600 Racing Brake Fluid if it will hold up better than the generic Autozone/O'Reily store brand.
I bought my FRS back in June of 2012 and I have a little over 32K miles on it now, but it wasn't until last year when I installed the Innovate super charger that I started having trouble getting into first gear and reverse on warm days (80+ F) or after a 20 minute track session. I checked the clutch fluid reservoir and the fluid is dark brown. I'm hoping that flushing the clutch fluid will help with this problem.
I searched the forums and I found a very informative DIY on how to replace the clutch slave cylinder, but I couldn't find anything on how much fluid I would need to flush the system and if there were any fluid preferences.
Thanks in advance for your help and suggestions
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
Old 02-14-2015, 11:22 AM   #2
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
I use the same as I do in my brakes, ATE TYP 200. Slightly lower boiling point than RBF, but it's half the price and if you boil any decent DOT4 you should look at cooling solutions rather than fluid solutions.
*edit, it does not take much fluid at all. You can do your brake system and clutch on one liter easily.
Decay107 is offline   Reply With Quote
Old 02-14-2015, 12:54 PM   #3
JB86'd
JB86'd's Avatar
Drives: JAWS
I just recently did the clutch slave cylinder swap and I just used the standard Subaru brake fluid, works fine as far as I know.
Old 02-14-2015, 02:37 PM   #4
tomaszjanczak
Drives: Silver Subaru BRZ
I used Motul RBF600 and bought two 0.5 liter bottles. $30 shipped
tomaszjanczak is offline   Reply With Quote
Old 02-18-2015, 01:17 AM   #5
MINOCIN
MINOCIN's Avatar
Thanks guys. I decided to go ahead and purchase some RBF600 from Counter Space Garage since I was already making a couple of other purchase with them anyway. I purchased two 500 mL bottles.
I'm hoping the fluid flush will help with the clutch problem. I agree that addressing the heat issue directly would be best if it is indeed the culprit,but as we all know combating the heat isn't easy, especially when you are at the track.
Old 02-18-2015, 01:53 AM   #6
Koa
Ultra's forester slave cylinder retrofit is simply awesome. One of the first mods I've done on the car and I absolutely love how it improved clutch feel. Sorry for slightly OT
Old 08-23-2020, 05:02 AM   #7
Mykii
Noodleking
Mykii's Avatar
Drives: 2013 Firestorm FRS
Sorry to res this, but I've got the same thing going on-- new supercharger, probably older clutch fluid, hard to get into first gear at a stop. Hoping to get a decent idea for my next step.
2013 Firestorm FR-S, Kraftwerks C38 kit, FT-86 UEL Catted Headers, TRD D-Tip cat-back, Vibrant 1140 Resonator, Exedy Stage 1 Normal/smoother clutch that replaced the Stage 2 3-puck clutch, Exedy Lightweight flywheel, DSS carbon fiber driveshaft, TEIN springs on performance package Sachs dampers, Megan Racing Inner tie rods, 17x8 +35 Enkei Silver RPF1's, OS-Giken 1.5-way diff, J-Luth steering wheel and now a GKTech angle kit-- which rubs.
Mykii is offline   Reply With Quote
Old 08-24-2020, 12:07 PM   #8
DarkSunrise
DarkSunrise's Avatar
Changed out my clutch fluid using the generic yellow bottle Prestone DOT 4 brake fluid. Didn't really notice any difference to be honest. Shifts were fine before and fine afterwards.
Fresh transmission fluid and adjusting the clutch engagement point a little higher made the biggest difference for me in terms of smoother shifting.
2022 BRZ Build
2013 FR-S Build
Brake and Clutch fluid questions ducky106 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 03-04-2019 08:58 AM
Another reason to love this car: Clutch Bleeding rice_classic Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 43 09-18-2017 03:09 PM
Properly flushing/bleeding radiator fluid? swift996 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-30-2014 02:50 PM
Anyone doing brake bleeding with the "Gravity Method"? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 03-03-2013 02:53 PM
Brake bleeding order? ubersoph Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-10-2012 07:13 AM
