Drives: Scion FRS
Brake and Clutch fluid questions
So new guy here and I have a question about the little screen on the brake fluid. Mine has caught some green stuff in it and I was wondering if any of you knew what it was/knew if its a problem. It looks like this
![]() Also if any one knew how much fluid is needed to do a complete flush of the brake and clutch, sharing that info would be great. Thanks |
Drives: 2013 Pearl White BRZ Limited
Common residue found in brake systems. Pay it no mind.
Shawn |
#3 | |
Drives: Attitude
Drives: Scion FRS
Thanks!
Shipping to Hawaii?...
Drives: '13 Asphalt FR-S
I barely used one super blue 1L bottle for both brakes and clutch. Don't know how big the Motul containers are. =P
~Matt
Efimia (asphalt FRS) |
Drives: 2013 BRZ Limited - WRB, MT
Is there a diy somewhere for the clutch fluid?
Drives: Scion FRS
The clutch is really easy, the slave cylinder is on top of the transmission, dead center latterally, and very close to the master. It is no different then bleeding the brakes, except you will have to manually pull the clutch back up.
Enthusiast 86
Drives: Toyota 86 GT
I changed my brake fluid recently, but then its new to me that there is clutch fluid next to the brake fluid tank.
When should i change the clutch fluid, i presume its break fluid that should be used (dot 4)? |
From the picture it looks like the green stuff is before the tank caught by the filter.
| Brake fluid question | barabia | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 07-31-2013 11:08 PM |
| Cooked my brake fluid!!! | markitect | Tracking / Autocross / HPDE / Drifting | 18 | 07-11-2013 10:53 AM |
| Amount of Brake Fluid.... | THEmailman | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 04-13-2013 11:46 PM |
| Brake fluid leak.. | tintumz22 | Issues | Warranty | Recalls / TSB | 9 | 02-01-2013 03:20 PM |
| Track Day Brake Fluid | Skorov | AUSTRALIA | 2 | 11-11-2012 07:10 PM |
